I was working on some code and I noticed the usage of both time.localtime() and RTC.datetime() to get the current date. The code is supposed to set the date of the internal rtc on power on.
### timeutil module ###
import machine, pyb
class Rtc:
def __init__(self):
# initialise RTC object
self.rtc = pyb.RTC()
# set rtc from user defined date and time only on power on
if (machine.reset_cause() != machine.DEEPSLEEP_RESET):
self.rtc.datetime(cfg.START_DATETIME)
def datetime(self):
return self.rtc.datetime() # returns a tuple (year, month, day, weekday, hours, minutes, seconds, subseconds)
rtc = Rtc()
def datetime():
return rtc.datetime()
Is there any reason to use one over the other to get the current date ? If not I don’t think I need to keep my Rtc object.
