Is it possible to run a tensorflow regression model on openmv?
I’ve created a regression model with edgeimpulse but when I run the inference on the MCU I only get the confidence value (as I have no labels).
You can run a classification model. What do you mean by a regression model? What are you trying to do?
I have a mechanical crackmeter (see example ) and have trained a regression model with edge impulse to predict the x axis deplacement. The live classification gives me a scalar value on edgeimpulse platform but when I deploy on my vision Sheild
I 'm not able to get the scalar value, only the confidence score.
This is the same isn’t it though? The confidence score is a value between 0->1 or 0->255?
It s a value between 0 & 1
Can you post your code and the output?
the code :
import sensor, image, time, os, tf
sensor.set_windowing((240, 240)) # Set 240x240 window.
sensor.skip_frames(time=2000) # Let the camera adjust.
net = "trained.tflite"
# default settings just do one detection... change them to search the image...
for obj in tf.classify(net, img, min_scale=1.0, scale_mul=0.8, x_overlap=0.5, y_overlap=0.5):
print("**********\nPredictions at [x=%d,y=%d,w=%d,h=%d]" % obj.rect())
img.draw_rectangle(obj.rect())
predictions =obj.output()
for pred in predictions:
print(pred)
as per the serial output :
Predictions at [x=0,y=0,w=240,h=240]
0.372549
6.19775 fps
0.341176
6.19779 fps
0.313725
6.19783 fps
0.262745
6.19786 fps
0.215686
6.19779 fps
0.235294
6.19783 fps
0.278431
6.19787 fps
0.184314
6.1979 fps
0.0705882
6.19794 fps
0.278431
6.19797 fps
0.376471
6.1979 fps
0.262745
6.19794 fps
0.490196
6.19798 fps
thanks
Just multiply 0.313725 * 255
The 0.313725 is just the output you see in Edge Impulse divided by 255.
