Hi everyone,
I am trying to connect thought SPI an LCD screen and a CAN module to an Arduino Nicla Vision. But the connexion while running, the code seems stop (no flags printed), and openmv disconnect the arduino or simply crash !
I am working on the CAN module with an MCP2515, I modified some code I found .
First I used multiple files but either openmv copy them on the Nicla and don’t find them causing error (!?) or simply crash.
So I put everything in a .py file and then it seems run but without printing flags.
This is the code :
=====IMPORT =====
from ustruct import pack, unpack, pack_into
from pyb import Pin, SPI #from machine import SPI
import utime
from micropython import const
===== CLASSES =====
# SPI instructions:
class mcp_spi():
RESET = const(0xC0)
READ = const(0x03)
READ_RX_BUFFER_0 = const(0x90)
READ_RX_BUFFER_1 = const(0x94)
WRITE = const(0x02)
WRITE_TX_BUFFER_0 = const(0x40)
WRITE_TX_BUFFER_1 = const(0x42)
WRITE_TX_BUFFER_2 = const(0x44)
READ_STATUS = const(0xA0)
RX_STATUS = const(0xB0)
BIT_MODIFY = const(0x05)
RTS0 = const(0x81)
RTS1 = const(0x82)
RTS2 = const(0x84)
# operating modes
class op_mode():
op_mask = const(0xE0)
normal = const(0x00)
sleep = const(0x20)
loopback = const(0x40)
listen = const(0x60)
configuration = const(0x80)
# address to registers
class address():
CANCTRL = const(0x0F)
CANSTAT = const(0x0E)
CNF1 = const(0x2A)
CNF2 = const(0x29)
CNF3 = const(0x28)
===== CAN =====
class CAN:
def __init__(self):
self.spi = SPI(4, SPI.MASTER, baudrate=int(1e6), polarity=0, phase=0)
self.cs = Pin("PA10", Pin.OUT)
self.msgbuf = bytearray(13) # for loading and retrieving messages
self.buf8 = bytearray(1) # for reading adresses
# SPI helper methods
def spi_start(self):
self.spi.init(SPI.MASTER, baudrate=int(1e6), polarity=0, phase=0, bits=8, firstbit=SPI.MSB)
self.cs.off()
def spi_end(self):
self.cs.on()
self.spi.deinit()
def write_register(self, address, data):
self.spi_start()
self.spi.write(pack("<B", mcp_spi.WRITE))
self.spi.write(pack("<B", address))
for byte in data:
self.spi.write(pack("<B", byte))
self.spi_end()
def bitmodify_register(self, address, mask, data):
self.spi_start()
self.spi.write(pack("<B", mcp_spi.BIT_MODIFY))
self.spi.write(pack("<B", mask))
self.spi.write(pack("<B", data))
self.spi_end()
def read_register(self, address):
self.spi_start()
self.spi.write(pack("<B", mcp_spi.READ))
self.spi.readinto(self.buf8)
self.spi_end()
def reset(self):
self.spi_start()
self.spi.write(pack("<B", mcp_spi.RESET))
self.spi_end()
def read_rx_buffer(self, buffer=0):
self.spi_start()
if buffer == 0:
self.spi.write(pack("<B", mcp_spi.READ_RX_BUFFER_0))
if buffer == 1:
self.spi.write(pack("<B", mcp_spi.READ_RX_BUFFER_1))
self.spi.readinto(self.msgbuf)
self.spi_end()
def load_tx_buffer(self, buffer): #Write provided load whatever is in msgbuf to selected TX buffer
self.spi_start()
if buffer == 0:
self.spi.write(pack("<B", mcp_spi.WRITE_TX_BUFFER_0))
if buffer == 1:
self.spi.write(pack("<B", mcp_spi.WRITE_TX_BUFFER_1))
if buffer == 2:
self.spi.write(pack("<B", mcp_spi.WRITE_TX_BUFFER_2))
self.spi.write(self.msgbuf)
self.spi_end()
def request_to_send(self, buffer=0):
self.spi_start()
if buffer == 0:
self.spi.write(pack("<B", mcp_spi.RTS0))
if buffer == 1:
self.spi.write(pack("<B", mcp_spi.RTS1))
if buffer == 2:
self.spi.write(pack("<B", mcp_spi.RTS2))
self.spi_end()
def read_status(self): #Fetch recieve and transmit status and flags
self.spi_start()
self.spi.write(pack("<B", mcp_spi.READ_STATUS))
data = self.buf8[0]
self.spi_end()
status = {
"RX0IF": data & 0x01,
"RX1IF": data >> 1 & 0x01,
"TX0REQ": data >> 2 & 0x01,
"TX0IF": data >> 3 & 0x01,
"TX1REQ": data >> 4 & 0x01,
"TX1IF": data >> 5 & 0x01,
"TX2REQ": data >> 6 & 0x01,
"TX2IF": data >> 7 & 0x01,
return status
def rx_status(self):
self.spi_start()
self.spi.write(pack("<B", mcp_spi.RX_STATUS))
data = self.buf8[0]
self.spi_end()
status = {
"filter_match": data & 0x07,
"RTR": data >> 3 & 0x01,
"extendedID": data >> 4 & 0x01,
"RXB0": data >> 6 & 0x01,
"RXB1": data >> 7 & 0x01
return status
# SET MODES ----------------------------
def get_opmod(self):
self.read_register(address.CANSTAT)
opmod = self.buf8[0] >> 5
return opmod
# Set OPMOD on CANCTRL and check that the mode is sucessfuly set
def set_opmod(self, mode):
cur_mode = self.get_opmod()
if cur_mode == mode >> 5:
print("mode already set")
return
i = 0
while i < 10: # try to set mode 10 times
self.bitmodify_register(address.CANCTRL, op_mode.op_mask, mode)
print("mode sucessfully set")
return
print("retrying setting mode...")
i += 1
print("Failed setting mode")
return
# initiate CAN communication
def init(self,
bit_rate=1E6, #bit_rate: CAN bus bit rate (1Mbt)
clock_freq=1E7, #clock_freq: Can module occilator frequency (10 Mhz)
SJW=1, #SJW: synchronization Jump Width: 1 to 4, default(1)
BTLMODE=1, #BTLMODE: : PS2 Bit Time Length bit: 0 or 1, default(1)
SAM=0, #SAM: Sample Point Configuration bit: 0 or 1, default(0)
PRESEG=0, #PRESEG: lengh of propagation segment: default(2)
PHSEG1=2, #PHSEG1: lenght of PS1, default(7)
PHSEG2=2 #PHSEG2: lenght of PS2, default(2) (only valid when BTLMODE=1)
print("HI_1")
print("HI_2")
self.reset()
print("HI_3")
time.sleep_ms(10)
print("HI_4")
print("Entering configuration mode...")
self.set_opmod(op_mode.configuration)
print("calulating BRP and setting configuration registers 1, 2 and 3")
self._set_timing(bit_rate, clock_freq, SJW, BTLMODE,SAM, PRESEG, PHSEG1, PHSEG2)
print("Entering normal mode...")
self.set_opmod(op_mode.normal)
def _set_timing(
self,
bit_rate,
clock_freq,
SJW, #SJW: synchronization Jump Width: 1 to 4, default(1)
BTLMODE, #BTLMODE: : PS2 Bit Time Length bit: 0 or 1, default(0)
SAM, #SAM: Sample Point Configuration bit: 0 or 1, default(1)
PRESEG, #PHSEG1: lenght of PS1, default(7)
PHSEG1, #PHSEG2: lenght of PS2, default(6) (only valid when BTLMODE=1)
PHSEG2): #PRESEG: lengh of propagation segment: default(2)
# Calculate bit time and time quantum
bit_time = 1 / bit_rate
tq = bit_time / 16
# Calculate Baud rate prescaler
BRP = int((tq * clock_freq) / 2 - 1)
# assert BRP % 1 > 0, "warning, bit-rate and
# clock-frequency is not compatible"
# Set configuration register 1
SJW = SJW - 1 # length of 1 is 0 etc.
assert len(bin(SJW)) - 2 <= 2, "SJW must be 1 to 4"
assert len(bin(BRP)) - 2 <= 5, "BRP must be under 31"
self.bitmodify_register(address.CNF1, 0xc0, SJW << 6)
self.bitmodify_register(address.CNF1, 0x3f, BRP)
# Set configuration register 2
assert len(bin(BTLMODE)) - 2 <= 1, "BTLMODE must be 0 or 1"
assert len(bin(SAM)) - 2 <= 1, "SAM must be 0 or 1"
assert len(bin(PHSEG1)) - 2 <= 3, "PHSEG1 must be 0 to 7"
assert len(bin(PRESEG)) - 2 <= 3, "PRESEG must be 0 to 7"
self.bitmodify_register(address.CNF2, 0x80, BTLMODE << 7)
self.bitmodify_register(address.CNF2, 0x40, SAM << 6)
self.bitmodify_register(address.CNF2, 0x38, PHSEG1 << 3)
self.bitmodify_register(address.CNF2, 0x07, PRESEG)
# Set configuration register 3
assert len(bin(PHSEG2)) - 2 <= 3, "PHSEG2 must be 0 to 7"
self.bitmodify_register(address.CNF3, 0x07, PHSEG2)
# Filter and masks (currently not working)
def set_filter(self, id=0x000, filter=0, extendedID=False, clear=False):
address = [0x00, 0x04, 0x08, 0x10, 0x14, 0x18]
if filter <= 1:
mask_address = 0x20
ctrl_address = 0x60
mask_address = 0x24
ctrl_address = 0x70
self._prepare_id(id, extendedID)
self.write_register(address=address[filter], data=self.msgbuf[0:4])
self.write_register(address=mask_address, data=[
0xff, 0xff, 0x00, 0x00])
self.bitmodify_register(ctrl_address, 0x60, 0x00) # activate filtering
if clear:
self.bitmodify_register(0x60, 0x60, 0xff) # clear filtering
self.bitmodify_register(0x70, 0x60, 0xff) # clear filtering
def _prepare_id(self, id, ext):
info = [0, 0, 0, 0]
if ext:
id = id & 0x1fffffff
info[3] = id & 0xff
info[2] = id >> 8
id = id >> 16
info[1] = id & 0x03
info[1] += (id & 0x1c) << 3
info[1] |= 0x08
info[0] = id >> 5
id = id & 0x7ff
info[0] = id >> 3
info[1] = (id & 0x07) << 5
info[2] = 0
info[3] = 0
pack_into("<4B", self.msgbuf, 0, *info)
# read messages
def read_message(self):
"""returns a dictionary containing message info
rtr: remote transmit request
extended: extended id
data_lenght: number of bytes recieved
data: list of bytes"""
# fetch recieve status
status = self.rx_status()
if status["RXB0"] == 1:
self.read_rx_buffer(buffer=0)
elif status["RXB1"] == 1:
self.read_rx_buffer(buffer=1)
return False # exit if no buffer is full
id = self.msgbuf[0] << 3 | self.msgbuf[1] >> 5
if status["extendedID"]:
id = id << 8 | self.msgbuf[2]
id = id << 8 | self.msgbuf[3]
data_length = self.msgbuf[4] & 0x0f
if data_length > 0:
data = list(self.msgbuf[5:5+data_length])
data = list()
message = {
"id": id,
"RTR": status["RTR"],
"extendedID": status["extendedID"],
"data_length": data_length,
"data": data
return message
# Write message
def write_message(self, id, data, rtr=0, extendedID=False):
"""Prepares a message to be sent on available trasmission buffer
id: a standar or extended message id
message: list of bytes max = 8
rtr: remote transmission request, if 1, no data is sent, default(0)
extendedID: Set to True if message ID is extended, else Fales
data_length = len(data)
if rtr:
dlc = data_length | 0x40
dlc = data_length
self.msgbuf[4] = dlc
self.msgbuf[5:5+data_length] = bytearray(data)
status = self.read_status()
if status["TX0REQ"] == 0:
self.load_tx_buffer(buffer=0)
self.request_to_send(buffer=0)
TXIF = 0x04
self.bitmodify_register(0x2c, TXIF, 0x00) # clear interupt flag
elif status["TX1REQ"] == 0:
self.load_tx_buffer(buffer=1)
self.request_to_send(buffer=1)
TXIF = 0x10
elif status["TX2REQ"] == 0:
self.load_tx_buffer(buffer=2)
self.request_to_send(buffer=2)
TXIF = 0x20
return # no transmit buffers are available
# quick function to check for incoming messages
def message_available(self):
if status["RXB0"] == 1 or status["RXB1"] == 1:
return True
return False
enableing and clearing interrupts -----------------
Enables interrupt conditions that will activate the INT pin.
Note: errors must be cleared by MCU.
use clear_message_error(), clear_wake_up()
and clear_errors() to clear these flags
tx_empty and rx_full are automatically cleared
when reading or writing messages
def enable_interrupts(self,
message_error=False,
wake_up=False,
errors=False,
tx0_empty=False,
tx1_empty=False,
tx2_empty=False,
rx0_full=False,
rx1_full=False):
if message_error:
self.bitmodify_register(0x2b, 0x80, 0xff)
if wake_up:
self.bitmodify_register(0x2b, 0x40, 0xff)
if errors:
self.bitmodify_register(0x2b, 0x20, 0xff)
if tx0_empty:
self.bitmodify_register(0x2b, 0x04, 0xff)
if tx1_empty:
self.bitmodify_register(0x2b, 0x08, 0xff)
if tx2_empty:
self.bitmodify_register(0x2b, 0x10, 0xff)
if rx0_full:
self.bitmodify_register(0x2b, 0x01, 0xff)
if rx1_full:
self.bitmodify_register(0x2b, 0x02, 0xff)
def clear_message_error(self):
self.bitmodify_register(0x2c, 0x80, 0x00)
def clear_wake_up(self):
"""Clears the wake-up interrupt flag and wakes-up the device"""
self.bitmodify_register(0x2c, 0x40, 0x00)
def clear_error(self):
self.bitmodify_register(0x2c, 0x20, 0x00)
def which_interrupt(self):
"""returns information about which interrupt condition
triggered the interrupt"""
self.read_register(0x0e)
i_code = self.buf8[0] >> 1 & 0x07
codes = ["No interrupts", "Error", "Wake-up", "TX0", "TX1", "TX2", "RX0", "RX1"]
return codes[i_code]
def abort_messages(self): #Request abort of all pending transmissions
self.bitmodify_register(0x0f, 0x10, 0xff)
===== MAIN =====
can = CAN()
can.init()
According to my test, openMV seems crash during the CAN.init() function.
Is it me who did something wrong or there is a bug from OpenIDE ? there are so few information about the arduino Nicla that I’m lost.
Thanks for your help.
