Hi - I’m tracking an april tag and sending AGV commands over a socket. I’m unit testing the code and for the life of me can’t get the HTTP GET that works at the top of the program to work inside a function… Code is below:
Line 34 works and moves the vehicle. Line 59 is caught as exception
---- terminal output----
Trying to connect... (may take a while)...
('192.168.1.2', '255.255.255.0', '192.168.1.1', '192.168.1.1')
Connected to 192.168.1.4:80
GET /jsData.html?x=-100&y=150 HTTP/1.1
Host: 192.168.1.4
b'HTTP/1.1 200 OK\r\nContent-Type: application/json\r\nContent-Length: 51\r\nConnection: close\r\n\r\n'
x=-91&y=150
b'GET /jsData.html?x=-91&y=150 HTTP/1.1\r\nHost: 192.168.1.4\r\n\r\n'
x=-93&y=150
b'GET /jsData.html?x=-93&y=150 HTTP/1.1\r\nHost: 192.168.1.4\r\n\r\n'
socket error: [Errno 22] EINVAL
File "<stdin>", line 65, in <module>
File "<stdin>", line 59, in start_following
OSError: [Errno 22] EINVAL
x=-94&y=150
b'GET /jsData.html?x=-94&y=150 HTTP/1.1\r\nHost: 192.168.1.4\r\n\r\n'
------------- end terminal output ------------
The code:
import sensor, image, time, network, usocket, sys , ubinascii, math, socket
sensor.set_framesize(sensor.HVGA) # we run out of memory if the resolution is much bigger...
sensor.set_windowing((180, 140)) # Look at center 160x120 pixels of the VGA resolution.
sensor.set_auto_gain(False) # must turn this off to prevent image washout...
sensor.set_auto_whitebal(False) # must turn this off to prevent image washout...
SSID="SSID" # Network SSID
KEY="PWD" # Network key
HOST ='' # Use first available interface
PORT = 80 # Arbitrary non-privileged port
# Init wlan module and connect to network
print("Trying to connect... (may take a while)...")
wlan = network.WINC()
wlan.connect(SSID, key=KEY, security=wlan.WPA_PSK)
# We should have a valid IP now via DHCP
print(wlan.ifconfig())
# Create a new socket and connect to addr
addr = usocket.getaddrinfo('192.168.1.4', 80)[0][-1]
client = socket.socket(socket.AF_INET, socket.SOCK_STREAM)
client.connect(addr)
print ('Connected to ' + addr[0] + ':' + str(addr[1]))
x_offset = -100
y_offset = 150
print("GET /jsData.html?x=%s&y=%s HTTP/1.1\r\nHost: %s\r\n\r\n"%(x_offset,y_offset,addr[0]))
client.send(bytes("GET /jsData.html?x=%s&y=%s HTTP/1.1\r\nHost: %s\r\n\r\n"%(x_offset,y_offset,addr[0]),'utf8')) #THIS WORKS AND AGV STARTS MOVING
print(client.recv(1024))
def map_range(x, in_min, in_max, out_min, out_max):
return (x - in_min) * (out_max - out_min) // (in_max - in_min) + out_min
def start_following(client):
for tag in img.find_apriltags(): # defaults to TAG36H11
img.draw_rectangle(tag.rect(), color = (255, 0, 0))
img.draw_cross(tag.cx(), tag.cy(), color = (0, 255, 0))
x_offset = int(tag.x_translation() * 100)
map_range(x_offset, -1000, 1000, -372, 372)
y_offset = int(tag.y_translation() * 100)
y_offset = 150
map_range(y_offset, -1000, 1000, -372, 372)
z_offset = int(tag.z_translation() * 100)
map_range(z_offset, -1000, 1000, -372, 372)
if z_offset < -450:
guidance = (x_offset, y_offset)
print("x=%s&y=%s" % guidance)
print(bytes("GET /jsData.html?x=%s&y=%s HTTP/1.1\r\nHost: %s\r\n\r\n"%(x_offset,y_offset,addr[0]),'utf8'))
client.send(bytes("GET /jsData.html?x=%s&y=%s HTTP/1.1\r\nHost: %s\r\n\r\n"%(x_offset,y_offset,addr[0]),'utf8')) #THIS IS CAUGHT as [Errno 22] EINVAL
#time.sleep_ms(500)
#print(clock.fps())
while (True):
except OSError as e:
print("socket error: ", e)
sys.print_exception(e)
