This topic is a further example of this bug How can RTC.wakeup() change global variables? - OpenMV Products - OpenMV Forums but separated to reduce clutter.
I find the RTC.wakeup() clock works differently depending on whether I Invoke machine.sleep(). To get correct behaviour I must call either:
rtc.wakeup(timerInterval, timerISR) if not sleeping or rtc.wakeup(timerInterval, timerISR(1)) if sleeping - i.e. with or without the dummy argument.
The code below should wake the processor every 4s, and I can specify whether or not to sleep by one of two options at lines 10 or 11.
With sleep disabled it works correctly if I call rtc.wakeup(timerInterval, timerISR). But if I call rtc.wakeup(timerInterval, timerISR(1)) then the callback appears to happen immediately (rather than after 4s) and then never again.
With sleep enabled it works correctly only if I call rtc.wakeup(timerInterval, timerISR(1)) at both lines 44 and 59. Other combinations give errors, such as the “timerTriggered” flag not being set. If I enable rtc.wakeup(timerInterval, timerISR) at line 44 and leave lines 59 and 60 commented out, the 4s interrupt happnes but “timerTriggered” flag is set every second time!
import pyb, machine, time, utime
global timerTriggered
timerTriggered = False
timerInterval = 4000
# Choose one or other:
enableSleep = True
#enableSleep = False
green_led = pyb.LED(2)
green_led.off()
blue_led = pyb.LED(3)
blue_led.off()
def flashGreen():
green_led.on()
utime.sleep_ms(200)
green_led.off()
utime.sleep_ms(200)
def flashBlue():
blue_led.on()
utime.sleep_ms(200)
blue_led.off()
utime.sleep_ms(200)
def timerISR(arg):
timerTriggered = True
if enableSleep:
print("Testing wakeup ISR (while sleeping)")
print("Testing wakeup ISR (while NOT sleeping)")
rtc = pyb.RTC()
utime.sleep_ms(200) # delay to ensure the print output happens before we sleep
# Experimentally, I find I have to use this when machine.sleep() is enabled:
#rtc.wakeup(timerInterval, timerISR(1))
# and I have to use this when machine.sleep() is not enabled
while (True):
if enableSleep:
# We enable sleep and wait for a timerinterrupt
machine.sleep()
if timerTriggered:
flashBlue()
#rtc.wakeup(timerInterval, timerISR)
flashGreen()
# We don't enable sleep, so we should loop through here with no LED activity
# UNTIL the timer interrupt sets a flag
if timerTriggered:
count = count + 1
print("Timer " + str(count))
flashBlue()
utime.sleep_ms(100) # so we don't run flat out....
