Hi. I have a quite specific problem. I am trying to sync a flash with a snapshot where the flash should be on only for a maximum of 10 to 15ms. I have been able to do this for resolutions up to HD by triggering the ov5640 by using its FREX function then calling snapshot after the END OF FRAME interrupt has been set to 1. Now i could have just used the sensor.get_frame_available() but this only returns False when only 1 frame buffer is used, which is the case for me where I’m trying to make this work for WQXGA2. My code is below.
import sensor
from machine import Pin, Timer
EOFADDRESS = 0x3F0C
pin8 = Pin(8, Pin.OUT)
def check_eof_status():
# Read the EOF status register
eof_status = sensor.__read_reg(EOFADDRESS)
eof_bit = (eof_status >> 5) & 1 # Extract bit 6 for EOF status
return eof_bit
def reset_eof_status():
eof_status |= (1 << 5)
sensor.__write_reg(EOFADDRESS,eof_status)
def led_func(t):
pin8.value(0)
sensor.set_framesize(sensor.WQXGA2)
sensor.__write_reg(0x3B07, 0x01) # mode 1
sensor.__write_reg(0x3B00, 0x81) # FREX enable
sensor.skip_frames(time=2000) # Wait for settings take effect.
i=1
timer = Timer(-1)
while i < 6: #try taking 5 images with flash
print(check_eof_status())
reset_eof_status()
sensor.__write_reg(0x3B08, 0x01) # Trigger FREX request
pin8.value(1)
timer.init(period=(10), mode=Timer.ONE_SHOT, callback=led_func)
while sensor.__read_reg(0x3B08) == 1:
endtrigger = time.ticks_ms()
while check_eof_status() == 0:
print("not available")
time.sleep_ms(1)
reset_eof_status()
print("Time to trigger FREX: ", endtrigger-start, "ms")
img.save("frex" + str(i) + ".jpg")
print(i)
i+=1
My problem is that at higher resolution, snapshot misses the timing. This is probably because there is only 1 framebuffer available so when the triggered image is being written to the buffer and i call snapshot, it is instead skipped. I’ve tried calling snapshot as soon as possible after i trigger the camera but it doesn’t help unfortunately. Do you know any solution to this?
Any help is appreciated ![]()
