I wanted to use the RT1062 Cam with a FLIR Lepton as a webcam. Do I need any specific firmware?
Hi, while the system can be used this way, it’s easier if you just buy PureThermal 3 by GetLab | GroupGets
Hi @kwagyeman
Thank you for your suggestion. I will check out the PureThermal 3. However, since I have already invested in the Cam RT1062 + Lepton Adapter, I am curious to know how we can use UVC in the current firmware.
It only compiles for the H7/H7 Plus. You’d have to figure it out for the RT1062. We are not actively maintaining the UVC firmware.
