RGB565 / LAB averaging
When averaging pixel values as proposed in Get RGB histogram statistics (not in LAB format!) - #5 by kwagyeman, is the average taken from the raw uncompressed (not jpeg compressed) RGB565 image? What is the exact processing pipeline here? RGB565 → lab888 → avg() → send()?
The script below shows the code I’m using to calculate the average on an OpenMV H7 plus.
    import sensor, image, utime, pyb, omv
    omv.disable_fb(True)
    sensor.ioctl(sensor.IOCTL_SET_READOUT_WINDOW, (0,0,800,600))
    sensor.set_framesize(sensor.SVGA)
    sensor.set_windowing((300,300))
        F1 = utime.ticks_ms()/1000
        h = img.histogram().get_statistics()
        LABvals = (h[0], h[8], h[16])   #LAB
        RGBvals = image.lab_to_rgb(LABvals)
        print(RGBvals)
        F2 = utime.ticks_ms()/1000
        print("FPS: ", 1/(F2-F1))
Yeah, RGB565 → LAB888
and the rgb565 is the uncompressed image, not jpeg compressed?
Yep! It’s not compressed onboard.
