The camera displays color images in real time, and saving the color images as pgm format images is convenient for face recognition
This is my codes:
Hello World Example
Welcome to the OpenMV IDE! Click on the green run arrow button below to run the script!
import sensor, image, time
#img1=image.Image(“orl_faces/test5/1.jpg”)
img2=img.to_grayscale([copy=False[, rgb_channel=-1]])
img2.save(“orl_faces/test5/1.pgm”)
break # to the IDE. The FPS should increase once disconnected.
