I’m trying to save an image when a blob is detected. It works for 1 to 5 saves, but then crashes the program and I have to reconnect. Guessing it is a memory issue, but I’m unclear on how to resolve it. Here is the code in question:
blobs = img.find_blobs([thresholds[threshold_index]])
if len(blobs) > 0:
sensor.snapshot().save("test.bmp") # or "example.bmp" (or others)
pin1.value(1)
pyb.delay(2000) # Time to save file
pin1.value(0)
Please post the full script, what is pin1 and threshold_index. I’m running your script now (but commented some lines, pin1 and threshold_index) and seems to be running fine.
Note: you’re running find_blobs twice in a row, not sure why. You can just loop through the blobs, and if you want to run else statement on empty loop I think Python syntax allows for… else. Also there’s no need to delay, save() will return after the file is written and flushed.
Sometimes it runs to up to 20 seconds, but it always disconnects on me. If I comment out the save line it runs fine. Code as follows:
import sensor, image, time, os, pyb
from pyb import Pin
pin1 = Pin('P1', Pin.OUT_PP, Pin.PULL_NONE)
threshold_index = 1 # 0 for red, 1 for green, 2 for blue
if len(blobs) > 0:
for blob in img.find_blobs([thresholds[threshold_index]], pixels_threshold=100, area_threshold=100, merge=True):
pin1.value(1)
pin1.value(0)
You’re using the new IDE version right? So, I made a change the IDE that causes it to disconnect from a cam if that camera doesn’t respond in 40 Ms to fix another bug. This generated the bug you are seeing. When you write a file to disk the camera may not respond to IDE requests for over 40 ms. This will be fixed in the next version of the IDE. In the mean time I can generate a fixed version of the IDE for you. I’ll post that in a bit.
