the usage examples are not clear enough. the example of using openmv color recognition in rgb is not clear how processing occurs when the color threshold is exceeded, since there is no “if” line in the example
Hi, there’s a wall of text in the documentation about what find blobs does. Please read it.
dear friend this is just an example. If you want an “if” statement you are free to use one!
Then you will be able to fire any output of the camera…
