Excuse me, please help me find out what is wrong with the following code, and why OpenMV always gets stuck and disconnected at the code
roi.find_keypoints(threshold=5,scale_facter=1.2,max_keypoints=150)
during execution. connect. Hope you can give me some advice.The following is the entire code of the program
import sensor, image, time
sensor.set_framesize(sensor.UXGA)
sensor.skip_frames(time=2000)
sensor.set_windowing((128,368,1400,706))
template = image.Image(“/model1.pgm”)
print(template)
kpts2 = template.find_keypoints(threshold=5,scale_facter=1.2,max_keypoints=150)
print(type(kpts2))
blobs = img.find_blobs([(178, 251)],area_threshold=1000)
if blobs:
print(blobs)
for blob in blobs:
x, y = blob.cx(), blob.cy()
roi = img.crop(blob.rect())
print(roi)
kpts1 = roi.find_keypoints(threshold=5,scale_facter=1.2,max_keypoints=150)
print(type(kpts1))
if len(kpts1) > 0:
match = image.match_descriptor(kpts2, kpts1, threshold=75)
if match:
img.draw_rectangle(blob.rect(), color=(255, 0, 0))
time.sleep(3)
If I replace corp with copy, there will be a memory overflow.
