Hey there,
I created my first haar cascade using opencv 2. The generated XML file works fine. When I try to convert the file however I get error messsages. The converted file also crashes the openmv cam after a couple of milliseconds. I´ll attach two screenshots and the cascade file. Could it be a problem that I used LBP featureType instead of Haar featureType when generating the opencv XML file?
Thank you very much in advance!
opencv.xml (288 KB)
