Problem with USB VCP
I want to communicate with OpenMV camera via USB. I was using OpenMV H7, and everything worked fine. I replaced the camera with the global shutter module, and updated the firmware. Everything works fine on the IDE, but I can not get usb_vcp.py working.
Since the example usb_vcp.py did not work, I tried the simpler example code from this post to test the communication. I repost the code below:
The main.py on OpenMV camera:
import ustruct
from pyb import USB_VCP
usb = USB_VCP()
        cmd = usb.recv(4, timeout=5000)
        if (cmd == b'snap'):
            usb.send(ustruct.pack("<L", 1234))
    except:
The corresponding python code on the PC:
import sys, serial, struct
port = '/dev/ttyACM0'
sp = serial.Serial(port, baudrate=115200,
                   bytesize=serial.EIGHTBITS,
                   parity=serial.PARITY_NONE,
                   xonxoff=False, rtscts=False,
                   stopbits=serial.STOPBITS_ONE,
                   timeout=None, dsrdtr=True)
sp.write(b"snap")
size = struct.unpack('<L', sp.read(4))[0]
sp.close()
print(size)
It works fine. I get 1234 as expected.
Once I changed the code to
import ustruct
import sensor
usb = USB_VCP()
sensor.skip_frames(time=2000)
    except:
I can only get 1885433459, where I should get 1234 as the previous code.
I am not sure how I should debug this. It would be great if there is some guidance. I appreciate the help in advance.
Probably main.py throws an exception here because the GS doesn’t support this format.
Thanks for the timely reply! That solves my problem! Thank you so much!
