Portenta H7 RGB LED intensity control
Hi, as per Arduino Portenta H7 MicroPython Cheat Sheet | Arduino Documentation, the RGB LED intensity should be configurable by defining between [0, 255]. I don’t think it’s working though. I ran the following program to check and the intensity values of extremes seem to be inverted
import pyb
r_led = pyb.LED(1)
r_led.intensity(0)          # LED off
print(r_led.intensity())
pyb.delay(5000)
r_led.intensity(100)        # LED mid intensity
pyb.delay(5000)
r_led.intensity(255)        # LED full intensity
pyb.delay(5000)
Output:
OpenMV v4.8.1; MicroPython v1.26.0-77; Arduino Portenta H7 with STM32H747
>>> 255
0
0
I suspect this is not a usable feature since there’s no pyb.LED(id).intensity() in class LED – LED object — MicroPython 1.26 documentation. Could you kindly confirm?
PC
Hi, LED intensity control on any STM32H7 boards is not preserved. The Timer used for that was used for the camera pixel clock.
Thanks for confirming Kwabena! Perhaps Arduino should update their docs :slight_smile:
PC
