Plot Profile function
Is there something similar to the Plot Profile function of ImageJ (with a rectangle) Plot Profile [ImageJ Documentation Wiki]? Not looking to plot a chart but interested in the data. Currently looking at a blob that has been binarized and trying to characterize each blob. I do not want the total count of black pixels but to subdivide and get counts for each subdivision. Any help or ideas would be appreciated.
Um, there’s a x and y histogram method that will give you the projection of the blob in 1d each direction. This may be what you want.
I.e, the x histogram will return the count of pixels of every column in the blob binned into X number of bins. X will initially be the size of the width of the blob, but, you can make it smaller.
The y histogram will be for the rows of the blob.
If you just want a slice of the blob set the ROI of the blob to just that slice for find_blobs().
Thanks…Sounds like what I am looking for. I will give that a try.
I am trying out the x_hist_bins() function and getting no data. Is there something wrong calling it on a binarized image?
thresholds = (0, 0)
sensor.set_windowing((300, 120))       # Set 128x128 window.
    clock.tick()                    # Update the FPS clock.
    img.binary([(110, 255)])
    blobs = img.find_blobs([thresholds], pixels_threshold=2000, area_threshold=2000, merge=True)
    num = 0
    for blob in blobs:
        ##uncomment if needed##img.draw_rectangle(blob.rect(), color=127)
        if (blob.w() > 120 and blob.w() < 150) :
            index = blob
            hist = index.x_hist_bins()
            print(len(hist))
            num += 1
        if (blob.w() > 60 and blob.w() < 80) :
            rank = blob
            num += 1
/code]
You have to pass a flag to find_blobs() for it to populate the output since this takes a lot of CPU and RAM it doesn’t do it unless asked. Please see the API.
Thanks for the help that is exactly what I needed.
