Uploading: 88a7f986124b1a5a8ae634da09f63af.png…
Edge Impulse - OpenMV Image Classification Example
import sensor, image, time, os, tf, uos, gc
sensor.set_windowing((240, 240)) # Set 240x240 window.
sensor.skip_frames(time=2000) # Let the camera adjust.
net = None
labels = None
net = tf.load(“trained.tflite”, load_to_fb=uos.stat(‘trained.tflite’)[6] > (gc.mem_free() - (64*1024)))
except Exception as e:
print(e)
raise Exception(‘Failed to load “trained.tflite”, did you copy the .tflite and labels.txt file onto the mass-storage device? (’ + str(e) + ‘)’)
labels = [line.rstrip(‘\n’) for line in open(“labels.txt”)]
raise Exception(‘Failed to load “labels.txt”, did you copy the .tflite and labels.txt file onto the mass-storage device? (’ + str(e) + ‘)’)
# default settings just do one detection... change them to search the image...
for obj in net.classify(img, min_scale=1.0, scale_mul=0.8, x_overlap=0.5, y_overlap=0.5):
print("**********\nPredictions at [x=%d,y=%d,w=%d,h=%d]" % obj.rect())
img.draw_rectangle(obj.rect())
# This combines the labels and confidence values into a list of tuples
predictions_list = list(zip(labels, obj.output()))
for i in range(len(predictions_list)):
print("%s = %f" % (predictions_list[i][0], predictions_list[i][1]))
