Hi again! It is for power saving yes, but I need it to be completely off as even 10mA is too high for what I need.
yes 10ma is to high but i dont think that this is power consuption.
did yoy try it? did you measure it? did you check these too:
https://docs.openmv.io/library/pyb.html#power-related-functions
So using machine.sleep(), the power consumption is 25mA measured. Using machine.sleep() and sensor.sleep(True) it goes down to 6mA which might be acceptable, but then I can’t wake up the sensor again.
there are more you can do like deepsleep and wake via external interrupt.
check manual…
Yes, I got it down to 6mA which might be OK, but now sleep disables USB and when I wake-up I can no longer transmit data by USB. Any ideas?
you can add some lines to check if there is a usb connection and then send data.
