OpenMV disconneted after several seconds when connecting to STM32
I’m trying to enable the openmv to send information to the STM32 board by using UART. When the openmv is connected to the computer and using IDE, it works fine. However, if the openmv works without computer but powered by STM32, it crashes within seconds (the red LED blinks twice). I’ve comfirmed it by setting the green LED turned on when openmv is functioning.
If I comment the UART code, the openmv works fine. So, there must be something wrong with UART.
How can I fix it?
This is my code:
from pid import PID
from pyb import UART, LED
rho_weight = 1
theta_weight = 1
w = 80
h = 60
mid_x = w/2
mid_y = h/2
gain = 5
uart = UART(3, 115200, timeout_char = 1000)
green_led = LED(2)
def pooling_filter(img):
    img.midpoint_pool(2, 2,bias=0.5)
    img.binary([(120,130)])
def find_middle_line(img):
        pooling_filter(img)
        line = img.get_regression([(240,255)], robust = True)
        img.draw_line(line.line(), color = 139,thickness=2)
        rho_error, theta_error = line_to_theta_and_rho(line.rho(),line.theta())
        return rho_error, theta_error
    except:
        return 0,0
def line_to_theta_and_rho(rho,theta):
    if rho < 0:
        trans_rho = -rho
        trans_theta = theta + 180
        trans_rho = rho
        trans_theta = theta
    cos_trans_theta = math.cos(math.radians(trans_theta))
    sin_trans_theta = math.sin(math.radians(trans_theta))
    distance = abs(mid_x*cos_trans_theta + mid_y*sin_trans_theta - trans_rho)
    if trans_theta == 90 or trans_theta == 270:
        distance_error = theta_error = 0
    elif (trans_rho-mid_y*sin_trans_theta)/cos_trans_theta > mid_x:
        distance_error = distance
        if theta > 90:
            theta_error = theta - 180
            theta_error = theta
        distance_error = -distance
        if theta > 90:
            theta_error = theta
    return distance_error, theta_error
    img.find_edges(image.EDGE_CANNY, threshold=(150,190))
    rho_error,theta_error = find_middle_line(img)
    if count != 10:
        if count == 0:
            rho_error_sum = theta_error_sum = 0
        rho_error_sum += rho_error
        theta_error_sum += theta_error
        rho_error_sum /= 10
        theta_error_sum /= 10
    rho_pid = PID(p=0.40, i=0.1, d=0, imax=10)
    theta_pid = PID(p=0.25, i=0.1, d=0, imax=10)
    rho_output = rho_pid.get_pid(rho_error_sum,1)
    theta_output = theta_pid.get_pid(theta_error_sum,1)
    output = gain*int(rho_weight*rho_output+theta_weight*theta_output)
    if output > 0:
        output = 'A'
        output = 'B'
    uart.write(str(output)+'\r\n')
    green_led.on()
    print('output=',output)
Can you make a reduced example that shows the crash?
