Hi everyone,
I am working on a computer vision project using OpenMV to measure filament diameter. I send configuration commands to the camera via USB VCP from a custom desktop interface.
I am trying to save a calibration value to the camera’s local flash storage in JSON format (kalibrasyon.json). However, when my script tries to execute open("kalibrasyon.json", "w"), I get an “Access Denied” error in the OpenMV IDE, and the file cannot be written.
Here is the relevant part of my code:
Python
import sensor, image, time, pyb, json, os
usb = pyb.USB_VCP()
CAL_FILE = "/kalibrasyon.json"
if usb.any():
cmd = usb.readline().decode().strip()
if cmd.startswith("SET_CAL:"):
val = float(cmd.split(":")[1])
# Getting "Access Denied" error on the below write operation
with open(CAL_FILE, "w") as f:
f.write(json.dumps({"scale": val}))
usb.write(json.dumps({"status":"ok", "scale":val})+"\n")
Is there a specific permission, mount setting, or workaround required to write data to the flash memory dynamically while the while True loop is running?
Any help is appreciated. Thanks!
