Object detection using Openmv H7 R2 cam
Hello. Can i know how to run this program (see attached) i had train and test in edge impulse for the object as bottles and cans and also converted to openmv library file but when i copy and paste the (trained.tflite) and (labels) into the cam drive folder and run it then it pops out with a message (OSError: The path name format is invalid) what should i do to make this project run ?
PLEASE HELP ME WITH THIS PROJECT THANK YOU !!
the runned coding
have you tried the path as “trained.tflite” instead of ‘<trained.tflite>’
1
its popping out this now !!
what should i do ?
I’m new to OpenMV too but have you tried doing what the warning suggests you to do? i…e to reduce the resolution of the image? Seems like you’re running out of memory
i did but i wan my output to state that its a bottle but in my case it shows nothing just the box color change to green when it detect bottle (see attached) my output it wil show in decimal point and can i know how to thicken the green border line as in the picture to identify the bottle ??
Change the arguments to draw_rectangle() and increase the width.
df
it stated this sir !!
