I’m using an open MV H7 to send data to an Arduino via UART. This works fine when I run my script in the IDE.
When the H7 is removed from USB, no data is coming over UART (I confirmed this by looking at the serial bus on the arduino with mySerial.available()).
The H7 is warm to the touch so it might be doing something and not writing the data. My script is loaded to the H7 as main.py.
Am I missing something?
Here is my H7 code:
from pyb import UART
# UART 3, and baudrate.
uart = pyb.UART(3, 19200, timeout_char = 1000)
# OpenMV Cam Ground Pin ----> Arduino Ground
# OpenMV Cam UART3_TX(P4) ----> Arduino UART_RX(0)
# OpenMV Cam UART3_RX(P5) ----> Arduino UART_TX(1)
# OpenMV Cam 5Vin to buck
#print("No objects, sending x = ",1)
uart.write("%d\n" % (1))
#wait until arduino acknoledges, which writes a char to the H7 once the first packet of info is recieved.
if(uart.readchar()!= -1):
#write Y
#print("No objects, sending y =", 1)
break
From the arduino
//UART (IMAGE) constructors (strange because this is for a nano33)
UART mySerial (digitalPinToPinName(0), digitalPinToPinName(1), NC, NC);
int max_len = 7; //Max length is 64 bytes
void setup(){
mySerial.begin(19200); //For UART to H7
void loop {
measureImage();
void measureImage() {
char xbuffer [63 + 1]; //A place to store all the chars 64
char ybuffer [63 + 1]; //A place to store all the chars 64
//Serial.print("Reading xbuffer from camera\n");
Serial.println("getline X");
getline(xbuffer, max_len); //Reads serial data, stores in buffer
Serial.println("getline complete");
//Serial.print("Determining x int");
X = getValue(xbuffer, true); //Gets the value in the buffer
Serial.println("writing ack");
mySerial.write('t');
//Serial.print("Reading ybuffer from camera\n");
Serial.println("getline Y");
getline(ybuffer, max_len); //Reads serial data, stores in buffer
//Serial.print("Determining y int");
Y = getValue(ybuffer, false); //Gets the value in the buffer
void getline(char *buffer, int max_len)
uint8_t idx = 0;
char c;
do
if (idx >= max_len) return;
while (mySerial.available() == 0){
//Code gets stuck here when not connected to IDE
c = mySerial.read();
buffer[idx++] = c;
while (c != '\n' && c != '\r');
buffer[idx] = 0;
#write Y
break
Does not run in the IDE. Please post the code that runs in the IDE. When I try to run the above I get pyb not defined on line “uart = pyb.UART(3, 19200, timeout_char = 1000)” as you never imported pyb. You used from which is not an import.
#Import libraries
import sensor, image, time, tf, math, pyb
uart.init(19200,bits=8,parity=None, stop=1, timeout_char=1000)
# OpenMV Cam UART3_TX(P4) ----> Arduino Uno UART_RX(0)
# OpenMV Cam UART3_RX(P5) ----> Arduino Uno UART_TX(1)
#Set camera sensor parameters
sensor.set_pixformat(sensor.GRAYSCALE) # grayscale is faster
sensor.set_auto_exposure(True)
#Begin clock
CAR_IMAGE_THRESHOLD = 3
CAR_IMAGE_SCALE = 0.25
BIKE_IMAGE_THRESHOLD = 2.0
BIKE_IMAGE_SCALE = 0.5
BUS_IMAGE_THRESHOLD = 2.0
BUS_IMAGE_SCALE = 0.5
MIN_AREA = 300
MAX_VARIANCE = 200
#Load cascade files for object identification in the image
#pedestrian_cascade = image.HaarCascade('pedestrian.cascade')
car_cascade = image.HaarCascade('cars.cascade')
#bike_cascade = image.HaarCascade('two_wheeler.cascade')
#bus_cascade = image.HaarCascade('Bus_front.cascade')
#Computes the mean of a set of data. Data is a list.
def means(data):
calc = sum(data)/len(data)
return calc
#Returns the standard deviation of the Cascade feature assessment. x and y are lists
def stddev(x,y):
sigmax = 0.0
sigmay = 0.0
N = len(x)
for i in range(N): #For every element that has been calculated so far
sigmax = sigmax+(x[i]*1.0-means(x))**2
sigmay = sigmay+(y[i]*1.0-means(y))**2
sigma = (math.sqrt((1/(N))*sigmax),math.sqrt((1/(N))*sigmay))
return sigma
#Calculates the confidence interval for the data.
def confidenceInterval(Xbar,N,s):
component = 1.960*(s/math.sqrt(N))
ci = (int(Xbar+component),int(Xbar-component))
return ci
#Determines where the object is located in the image frame. Not used.
def determineDirection(widths):
bins = 320/3
sides = []
for x in range(len(widths)):
if widths[x] <= bins:
sides.append("right")
elif widths[x] <= bins:
sides.append("center")
sides.append("left")
return sides
#Does some fancy statistics stuff to refine cascade detection. Returns an obj(x,y,w,h).
def featureSolve(cascade):
x = [] #Reset for every loop
y = [] #Reset for every loop
A = [] #Reset for every loop
#Produces a weighted rectangle for all cascade detections. Filters results.
for n in cascade: #For each car in the picture
x.append(n[0]) #Add the x cooridnate to our list
y.append(n[1]) #Add the y coordinate to our list
A.append(n[2]*n[3]) #Add the area of each shape to our list
i = 0
N = len(x)
if i == len(x):
#print("removed %d features" % (N-len(x)))
break
elif A[i] < MIN_AREA:#Min area check for far away objects
A.remove(A[i])
x.remove(x[i])
y.remove(y[i])
i = 0 #reset
elif abs(x[i]-means(x)) > MAX_VARIANCE or abs(x[i]-means(x)) > MAX_VARIANCE: #Spatial check
A.remove(A[i])
x.remove(x[i])
y.remove(y[i])
i = 0 #reset
i = i+1
if len(x) > 0:
sigma = stddev(x,y)
#Calculate the centroid of the data set
centroid = (0,0,0)
for i in range(len(x)):
#Properties is a tuple (A,xA, yA)
properties = (A[i],x[i]*A[i],y[i]*A[i])
#Compute the cumulative centroid (EA, ExA, EyA)
centroid = tuple(map(sum, zip(centroid, properties)))
X = centroid[1]/centroid[0] #X_bar = ExA/EA
Y = centroid[2]/centroid[0] #Y_bar = EyA/EA
#Calculates the confidence interval (Xbar,N,s). Returns (#+,#-).
xci = confidenceInterval(X,len(x),sigma[0])
yci = confidenceInterval(Y,len(y),sigma[1])
obj = (xci[0],yci[0],int(X)-xci[1],int(Y)-yci[1])
return obj #Return object tuple
#print("no objects within parameters")
return (0,0,0,0)
#Shows the vehicles on the image
def plotVehicles(obj):
#Plot all the objects
#draw the rectangle
img.draw_rectangle(obj,thickness = 3, color = (255,0,0))
# Draw the label above the face
img.draw_string(obj[0]+3, obj[1]-1, "Car", color = 70, mono_space=False)
return
#Main loop
time.sleep(1000) #Refresh rate
img = sensor.snapshot().lens_corr(1.9) #Take a picture
#Set cascade features here
car = img.find_features(car_cascade, threshold = CAR_IMAGE_THRESHOLD, scale = CAR_IMAGE_SCALE)
#bike = img.find_features(bike_cascade, threshold = BIKE_IMAGE_THRESHOLD, scale = BIKE_IMAGE_SCALE)
#bus = img.find_features(bus_cascade, threshold = BUS_IMAGE_THRESHOLD, scale = BUS_IMAGE_SCALE)
if sum(map(sum,car)) > 0:
carobj = featureSolve(car) #If features are present, generate an (X,Y,W,H) tuple
#print(carobj)
if sum(carobj) > 0:
plotVehicles(carobj)
#Write the centroid of the object to the Arduino
#Write x
print("sending x =", carobj[0])
uart.write("%d\n" % (carobj[0]))
while (True):
print("waiting to acknoledge")
#write Y
print("sending y =", carobj[1])
uart.write("%d\n" % (carobj[1]))
break
#else:
print("Not Acknoledged")
else: #No vehicles are detected
#write Y
break
#else:
#uart.write("%d%d\n" % (carobj[0],carobj[1]))
#if sum(map(sum,bike)) > 0:
# bikeobj = featureSolve(bike)
# plotVehicles(bikeobj)
#if sum(map(sum,bus)) > 0:
# busobj = featureSolve(bus)
# plotVehicles(busobj)
#print(clock.fps(), "fps")
Hi, I was just looking for the example code that fails to compile. Can you post the most simple working code possible that has an error which you cannot understand?
