I got the following problem when trying the micro_speech.py example code:
File "<stdin>", line 20, in <module>
File "ml/apps.py", line 52, in __init__
File "ml/model.py", line 36, in __init__
OSError: [Errno 19] ENODEV
OpenMV 5c5946a; MicroPython f71dd03d; Arduino Nicla Vision with STM32H747
def callback(label, scores):
print(f'\nHeard: "{label}" @{time.ticks_ms()}ms Scores: {scores}')
speech = MicroSpeech()
speech.listen(callback=callback, threshold=0.70)
To resolve this issue I tried to manually load the MicroSpeech object with the “audio_preprocessor.tflite” and “model.tflite”:
from ml.model import Model
speech = MicroSpeech(preprocessor=Model("audio_preprocessor.tflite"),micro_speech=Model("model.tflite"),labels=["Yes", "No"])
What leaves me with the following error:
File "<stdin>", line 9, in <module>
File "ml/apps.py", line 95, in listen
IndexError: list index out of range
Here is the listen function from apps.py
def listen(self, timeout=0, callback=None, threshold=0.65, filter=["Yes", "No"]):
self.start_audio_streaming()
stat_ms = time.ticks_ms()
average_scores = np.mean(self.pred_history, axis=0)
max_score_index = np.argmax(average_scores)
max_score = average_scores[max_score_index]
label = self.labels[max_score_index] # <--- line 95
if max_score > threshold and label in filter:
self.pred_history[:] = 0
self.spectrogram[:] = 0
if callback is None:
if timeout != -1: # non-blocking mode
self.stop_audio_streaming()
return (label, average_scores)
callback(label, average_scores)
if timeout == -1: # non-blocking mode
return (None, average_scores)
if timeout != 0 and (time.ticks_ms() - stat_ms) > timeout:
time.sleep_ms(1)
Ive already reset the firmware and the “audio_fft_1.py”-example works without problems.
I have no idea how I could approach this issue any further and would be happy if someone could help me out.
