Openmv H7 Plus using modified example works on older firmware v4.2.3 but non on v4.5.2.
stream.read(copy_to_fb=current_frame, loop=False, pause=False) fails with “TypeError: can’t convert Image to int”
Code to reproduce:
# Image Memory Stream I/O Example
# This example shows how to use the ImageIO stream to record frames in memory and play them back.
# Note: While this should work on any board, the board should have an SDRAM to be of any use.
import sensor
# Number of frames to pre-allocate and record
N_FRAMES = 500
sensor.set_framesize(sensor.QQQVGA) #resolution
# This frame size must match the image size passed to ImageIO
sensor.set_windowing((57, 24))
sensor.skip_frames(time=2000)
# Write to memory stream
stream = image.ImageIO((57, 24, sensor.GRAYSCALE), N_FRAMES)
for i in range(0, N_FRAMES):
stream.write(sensor.snapshot())
stream.seek(0)
current_frame = stream.read(copy_to_fb=False, loop=False, pause=False)
stream.seek(0)
# Rewind stream and play back
stream.seek(0)
img = stream.read(copy_to_fb=current_frame, loop=False, pause=False)
# Do machine vision algorithms on the image here.
