Hello, I am a newbie and need help with code, i have been trying wire OPENMV H7 with the two motors
the code i have uses the TB6612 , howver I am using two CytronMD10c
however the cyron has GND, PWM , DIR pins but the TB6612 is connected P0, P1, P2, P3 of the openmv with PWM on P7 and P8
I wasnt sure how to wire teh Cytron to the PWM so that the code will still work, unless i need to alter the code somewhow,
any help would be appreciated.
from pyb import Pin, Timer
inverse_left=False #change it to True to inverse left wheel
inverse_right=False #change it to True to inverse right wheel
ain1 = Pin(‘P0’, Pin.OUT_PP)
ain2 = Pin(‘P1’, Pin.OUT_PP)
bin1 = Pin(‘P2’, Pin.OUT_PP)
bin2 = Pin(‘P3’, Pin.OUT_PP)
ain1.low()
ain2.low()
bin1.low()
bin2.low()
pwma = Pin(‘P7’)
pwmb = Pin(‘P8’)
tim = Timer(4, freq=1000)
ch1 = tim.channel(1, Timer.PWM, pin=pwma)
ch2 = tim.channel(2, Timer.PWM, pin=pwmb)
ch1.pulse_width_percent(0)
ch2.pulse_width_percent(0)
def run(left_speed, right_speed):
if inverse_left==True:
left_speed=(-left_speed)
if inverse_right==True:
right_speed=(-right_speed)
if left_speed < 0:
ain1.low()
ain2.high()
ain1.high()
ain2.low()
ch1.pulse_width_percent(int(abs(left_speed)))
if right_speed < 0:
bin1.low()
bin2.high()
bin1.high()
bin2.low()
ch2.pulse_width_percent(int(abs(right_speed)))
