Hello guys and Merry Christmas first of all!!!
I’d like to ask 2 questions regarding IOCTL_SET_TRIGGERED_MODE.
I want to synchronize to cameras, and since i have a global shutter on both of my H7 cameras i went to use IOCTL_SET_TRIGGERED_MODE,True.
Before doing so, I tested the function in one of the example programs for global shutter, the high_fps.py and added the function.
I realized a HUGE drop of frames, from about 200 to about 100 frames in QQVGA when IOCTL_SET_TRIGGERED_MODE was true. I must mention here
that high fps for my project is very important (ball tracking project)
import sensor, image, time
sensor.set_pixformat(sensor.GRAYSCALE) # Set pixel format to GRAYSCALE
sensor.set_framesize(sensor.QQVGA) # Set frame size to QQVGA (160x120) - make smaller to go faster
sensor.set_auto_exposure(True, exposure_us=5000) # make smaller to go faster
sensor.ioctl(sensor.IOCTL_SET_TRIGGERED_MODE, True)
to the IDE. The FPS should increase once disconnected.
I thought that this mode would make fps even better ( i think i read it somewhere) , since the module does not wait for previous image to finish. Am i doing something wrong here?
The second problem was when i asked the program to take snapshots every 2 seconds, apart from the first image, all the others were full of snow … with a lot of noise. Why is that? When i run the same program with triggered mode set False, everything was fine.
Untitled - By: giaag - Πεμ Δεκ 24 2020
from pyb import Pin
sensor acquisition trigger when calling snapshot()
i=0
led = pyb.LED(1) # Red LED = 1, Green LED = 2, Blue LED = 3, IR LEDs = 4.
for i in range(10):
led.on()
fn=‘imgg_’+str(i)+‘.jpg’
img.save(fn,quality=100)
#print(fn)
led.off()
any suggestions would be welcome
Happy new Year guys!!!
