I want to send data audio and video streaming via socket. when i call function audio streaming and audio snapshot. Data that i got is bad. like audio data obtained feels laggy (audio data is cut off). when i call it just one function (just sensor.snapshot, or just audio streaming) data that I obtained is good. What sould i do to make data audio and video streaming that i send not being cut off ?
this is my code
# MJPEG Streaming
# This example shows off how to do MJPEG streaming to a FIREFOX webrowser
# Chrome, Firefox and MJpegViewer App on Android have been tested.
# Connect to the IP address/port printed out from ifconfig to view the stream.
import sensor, image, time, network, socket, sys, audio
from ulab import scipy as sp
import pyb,micropython
#micropython.alloc_emergency_exception_buf(100)
SSID='Data Pusaka 2.4' # Network SSID
KEY='admin.admin' # Network key
HOST ='x.x.x.x' # Use first available interface
PORT = 8080 # Arbitrary non-privileged port
CHANNELS = 1
SIZE = 256//(2*CHANNELS)
raw_buf = None
# Init sensor
sensor.set_auto_whitebal(False) # Turn off white balance.
audio.init(channels=CHANNELS, frequency=16000, gain_db=24, highpass=0.9883)
# Init wlan module and connect to network
print("Trying to connect... (This may take a while)...")
wlan.connect(SSID, KEY)
# We should have a valid IP now via DHCP
print("WiFi Connected ", wlan.ifconfig())
# Create server socket
s = socket.socket(socket.AF_INET, socket.SOCK_STREAM)
# Bind and listen
s.connect([HOST, PORT])
start_time_mic = pyb.millis()
start_time_vid = pyb.millis()
# Define the desired delay in milliseconds
delay_ms = 30
a = 1
data_buffer = bytearray()
current_time = 0
#sensor.set_framebuffers(3)
#sensor.set_windowing((20, 20, 20, 20)) # Contoh nilai, sesuaikan dengan kebutuhan
# Fungsi callback untuk pengambilan data audio
def audio_callback(buf):
global start_time_mic, data_buffer,current_time
current_time = time.ticks_ms()
elapsed_time_mic = current_time - start_time_mic
# Menambahkan data ke dalam buffer
data_buffer.extend(buf)
global start
# Start streaming images
# NOTE: Disable IDE preview to increase streaming FPS.
while ((current_time - start) > 30) and data_buffer:
# if elapsed_time_mic >= delay_ms and data_buffer:
# Mengirim data dari buffer ke server
s.sendall(data_buffer)
except Exception as e:
print("Error sending data:", e)
# start_time_mic = current_time
# time.sleep_ms(30)
audio.start_streaming(audio_callback)
# Set fungsi callback untuk timer
#timer.callback(capture_frames)
while (True):
# start_streaming(s)
# audio.start_streaming(audio_callback)
latest_frame = sensor.snapshot()
# time.sleep_ms(30)
# audio.stop_streaming()
except OSError as e:
print("socket error: ", e)
#sys.print_exception(e)
