In case your having problems with I2C connections
Simple I2C scanner
from pyb import I2C
i2c = I2C(2, I2C.MASTER, baudrate=100000)  # Use 100kHz for better compatibility
print("\r\nScanning I2C 2 bus, .")
devices = i2c.scan()
print(devices)
if not devices:
    print("❌ No I2C devices found. Check wiring, power, and pullups.\r\n")
    print("✅ I2C devices found:")
    for device in devices:
        print(" - Address: 0x{:02X}".format(device))
Recommend to use the machine module in the future.
Importing I2C from machine never worked
This works on the RT1062 for example:
import machine, time
bus = machine.I2C(2)
print(bus.scan())
your code worked on cam h7 plus, output in decimal
