Converting new XML formatâŚ
File âcascade_convert.pyâ, line 422, in
main()
File âcascade_convert.pyâ, line 419, in main
cascade_binary_universal(args.file, args.stages, args.name)
File âcascade_convert.pyâ, line 101, in cascade_binary_universal
cascade_binary(path, n_stages, name)
File âcascade_convert.pyâ, line 183, in cascade_binary
rects = feature[idx].getElementsByTagName(â_â)
IndexError: list index out of range haarcascade_frontalface_alt2.xml (528 KB)
Hi, support for the new Haar cascade format is somewhat limited, we only support 1 feature and 2 alpha per weak classifier. This cascade has 2 features and 3 alpha per weak classifier so itâs not going to work. See the haarcascade_frontalcatface.xml for an example of a supported new format cascade, or use the old format.
Does the cascade converter work on macos?I couldnt find the eye cascade binary in the Github directory, so had to generate it but it doesnt detect. I used the frontalface cascade binary provided and it works.
Thanks for the reply. If the binary generated from the provided eye cascade xml doesnât detect the eye, what could be the problem? i pass roi from the frontalface detect. I have attached my files. Could you please share me a working eye cascade binary, i am confused? eye.zip (63.8 KB)
face_eye_detection.py looks fine but it doesnt work with the eye cascade generated by me. I have attached the cascade in my previous post, could you please regenerate and try?
Thanks for the support. Much appreciated!
The script should generate an identical cascade. Note I never tested the converted on Mac (and it doesnât work on Windows) I can only confirm it works on Linux, you could try to run the script on Linux VM and compare the output.
I tried to use your cascade_convert.py to convert haarcascade_frontalcatface.xml but always failed. and I donât know why.
could you help me convert it?
Thanks a ton!
Thanks a ton!
Hi, please see the older replies to this thread. The script only works on Linux (for some reason) and it only supports the most basic Haar cascade (using the old format). If youâre having a different issue with the script please post the command you used and the error messages.
Hi iabdalkader,
thank you so much for your quick response and help!
Yes, I read and tried all the older replies but I canât find any right solution. I used Python 2.7.5 and 2.7.13 to run cascade_convert.py to convert but both of them did not work. Can you help me convert it? Please find haarcascade_frontalcatface.xml attached. Thank you so much.
I am looking forward to hearing back from you. haarcascade_frontalcatface.zip (241 KB)
Dear iabdalkader,
Thank you so much for your help and suggestion.
I will install Linux VM to convert cascades and also look forward to your fixing the script on Windows.
Hi:
The oemnv is great open vision library. Lately i apply it on some my research project.but i want to train my own cascade classfier.i train face_cascade.xml can detect face on opencv.
Howecer,i use openmv_casscade.py convert to face.cascade can not detect face on openmv.May you help me .Thank you very much.
Hrer is my cascade.xml. cascade.xml (39.9 KB)
