Hi I’m trying to make the make the line tracing robot by turn the image black and make the outline for the line I’m trying to track so the light level won’t effect the quality of the line tracing then make like a blob that at the center of the line & follow the line then send the degree back to my robot how can I achieve that here is the code I’m working with
import sensor
import math
from pyb import UART
# Initialize the camera
sensor.set_pixformat(sensor.GRAYSCALE) # grayscale is sufficient for line detection
sensor.set_framesize(sensor.QQVGA) # or any other size that suits your needs
sensor.skip_frames(time=2000)
sensor.set_auto_gain(False) # turn off automatic gain control
sensor.set_auto_whitebal(False) # turn off white balance
uart = UART(3, 19200, timeout_char=200)
GRAYSCALE_THRESHOLD = [(128, 255)]
ROIS = [ # [ROI, weight]
(0, 200, 320, 20, 0.6),
(0, 150, 320, 20, 0.2), # depending on how your robot is setup.
(0, 100, 320, 20, 0.1), # You'll need to tweak the weights for your app
(0, 50, 320, 20, 0.05), # depending on how your robot is setup.
# (0, 0, 320, 20, 0.05)
class ImageProcessor:
def __init__(self):
self.low_threshold = 260
self.high_threshold = 270
self.line_threshold = 1000 # Adjust this threshold
self.theta_margin = 100
self.rho_margin = 100
self.max_line_length = 100 # Set maximum line length
self.min_line_length = 10 # Set minimum line length
self.max_angle_diff = 20 # Set maximum angle difference for filtering
def process(self):
self.image = sensor.snapshot()
self.image.find_edges(image.EDGE_CANNY, threshold=(self.low_threshold, self.high_threshold))
def LineDetect(self):
for l in self.image.find_lines(
threshold=self.line_threshold,
theta_margin=self.theta_margin,
rho_margin=self.rho_margin,
max_line_length=self.max_line_length,
min_theta=-90,
max_theta=90
if self.min_line_length < l.length() < self.max_line_length:
# Check if line angle is within a certain range
if abs(l.theta() - 90) < self.max_angle_diff:
self.image.draw_line(l.line(), color=(255))
img_processor = ImageProcessor()
img_processor.process()
centroid_sum = 0
blobs_num = 0
last_pos = [160, 240]
for r in ROIS:
blobs = img_processor.image.find_blobs(GRAYSCALE_THRESHOLD, roi=r[0:4], merge=True)
except Exception as e:
print("Error occurred during blob detection:", e)
blobs = None # Set blobs to None to handle the error gracefully
if blobs:
# Find the blob with the most pixels.
largest_blob = max(blobs, key=lambda b: b.pixels())
if largest_blob.area() > 540:
blobs_num += 1
# Draw a rect around the blob.
img_processor.image.draw_rectangle(largest_blob.rect())
img_processor.image.draw_cross(largest_blob.cx(), largest_blob.cy())
last_pos = [largest_blob.cx(), largest_blob.cy()]
centroid_sum += (largest_blob.cx() - 160) * r[4] # r[4] is the roi weight.
center_pos = centroid_sum / sum(r[4] for r in ROIS) # Determine center of line.
degree = math.atan2(160 - last_pos[0], 240 - last_pos[1])
if blobs_num:
uart.write(f"{-1 * math.sin(degree)}\n")
uart.write("0\n")
if uart.any():
print(uart.read())
here the outline code alone
import sensor, image, time
def __init__(self):
def process(self):
for l in img.find_lines(
min_theta=-90,
max_theta=90
here the line tracing code
import sensor
import math
# UART 3, and baudrate.
# Tracks a black line. Use [(128, 255)] for a tracking a white line.
GRAYSCALE_THRESHOLD = [(0, 64)]
# Each roi is (x, y, w, h). The line detection algorithm will try to find the
# centroid of the largest blob in each roi. The x position of the centroids
# will then be averaged with different weights where the most weight is assigned
# to the roi near the bottom of the image and less to the next roi and so on.
(0, 200, 320, 25, 0.20),
(0, 175, 320, 25, 0.20),
(0, 150, 320, 25, 0.20),
(0, 125, 320, 25, 0.15),
(0, 100, 320, 25, 0.15),
(0, 75, 320, 25, 0.1),
#ROIS2 = [ # [ROI, weight]
# (0, 120, 20, 240, 0.2),
# (80, 120, 20, 240, 0.2), # depending on how your robot is setup.
# (160, 120, 20, 240, 0.2), # You'll need to tweak the weights for your app
# (240, 120, 20, 240, 0.2), # depending on how your robot is setup.
# (300, 120, 20, 240, 0.2)
#LP = [0,0,0,0,0,]
def distance(pos1, pos2):
return ((pos1[0] - pos2[0])**2 + (pos1[1] - pos2[1])**2)**0.5
# Compute the weight divisor (we're computing this so you don't have to make weights add to 1).
weight_sum = 0
for r in ROIS:
weight_sum += r[4] # r[4] is the roi weight.
# Camera setup...
sensor.set_pixformat(sensor.GRAYSCALE) # use grayscale.
sensor.set_framesize(sensor.QVGA) # use QQVGA for speed.
sensor.skip_frames(time=2000) # Let new settings take affect.
centroid_sum = 0
blobs_num = 0
# for r in ROIS2:
# blobs = img.find_blobs(
# GRAYSCALE_THRESHOLD, roi=r[0:4], merge=True
# ) # r[0:4] is roi tuple.
# if blobs:
# # Find the blob with the most pixels.
# largest_blob = max(blobs, key=lambda b: b.pixels())
# blobs_num += 1
# # Draw a rect around the blob.
# img.draw_rectangle(largest_blob.rect())
# img.draw_cross(largest_blob.cx(), largest_blob.cy())
# centroid_sum += largest_blob.cx() * r[4] # r[4] is the roi weight.
for r in ROIS:
if blobs:
largest_blob = max(blobs, key=lambda b: [-1 * distance(last_pos, [b.cx(), b.cy()]), b.pixels()])
if (largest_blob.area() > 540):
blobs_num += 1
center_pos = centroid_sum / weight_sum # Determine center of line.
if (blobs_num):
# uart.write(f"{center_pos}\n")
# print(math.sin(degree))
uart.write("0\n")
if uart.any():
print(uart.read())
# print(center_pos)
