Sorry for my stupid french question, but i want to use the 3 analog ports on my Arduino nicla Vision board.
no problem with the port A0 (ADC1/PC_4) with this line code :
adc = ADC(“A0”)
But if i want to use A2, this line code :
adc = ADC(“A2”)
OPENMV result is :
ValueError :Pin(F3) doesn’t habe ADC capabilities
Do you know the name of the port A2 and A3 in ADC function please ?
Thank you
TC
Hi, there’s some issue with the driver it looks like for the H7 on using multiple ADCs. It appears folks have been debating this for a while since 2021 and it wasn’t solved.
I just tried the code:
import machine, time
adc = machine.ADC("PF3")
print((adc.read_u16() / 65535.0) * 3.3)
and
adc = machine.ADC("PC4")
Work. However, PF13 doesn’t. It appears each of these pins is on a different internal ADC block which is the problem. I’ll raise this issue on our github for Ibrahim to see if it’s fixable.
I think you may have an older firmware. Nicla’s analog pins shouldn’t have any problems.
@Osiris1979
Please use the latest firmware via Tool->Install Development Firmware
and then all three channels will work through the machine module. Then PF13 will work.
adc = machine.ADC("PF13")
Please avoid using pyb unless absolutely necessary. It’s an obsolete module that is not maintained.
Hi
So many thanks for your help.
you were right.
It was just a firmware update.
For the “from pyb import ADC”, it was the BOARD example from OPENMV source.
adc0 = machine.ADC(“A0”)
adc1 = machine.ADC(“A1”)
adc2 = machine.ADC(“A2”)
print(“ADC 0 = %fv” % ((adc0.read_u16() / 65535.0) * 3.3))
print(“ADC 1 = %fv” % ((adc1.read_u16() / 65535.0) * 3.3))
print(“ADC 2 = %fv” % ((adc2.read_u16() / 65535.0) * 3.3))
