I was able to get the code to run and even export a message to an Arduino board. However, i keep running into the problem that sometimes am getting NameError: name ‘blob’ not defined. I have attached the code i think is causing the problem.
#initialize
for blob.raphe in img.find_blobs([threshold_raphe],pixels_threshold=100,area_threshold=100, merge=True):
img.draw_cross(blob.cx(),blob.cy())
if blob.raphe:
for blob.seed in img.find_blobs([threshold_seed],pixels_threshold=200,area_threshold=200, merge=True):
img.draw_string(blob.x()+2,blob.y()+2,"seed")
seedX = blob.x()
for blob.aril in img.find_blobs([threshod_aril],pixels_threshold=300,area_threshold=300, merge=True):
img.draw_string(blob.x()+2,blob.y()+2,"aril")
arilX = blob.x()
func_orientation();
func_fail()
