I want to send the aril.cy via UART with my pass or fail functions. This is what I have so far
from pyb import UART, ADC
import ulab
from ulab import numpy
#sensor.set_auto_gain(False) # must be turned off for color tracking
#sensor.set_auto_whitebal(False) # must be turned off for color tracking
threshold_seed = (7,24,-8,4,-3,9)
threshold_aril = (62,76,-20,-9,58,72)
threshold_raphe = (36,45,28,43,17,34)
thresholds = [threshold_seed,threshold_aril,threshold_raphe]
uart = UART(1, 9600)
uart.init(9600, bits=8, parity=None, stop=1)
limitLoop = 0
#FUNCTIONS
#global seed
#global aril
def func_position(arilY):
aril.cy = bytes(8)
def func_pass():
#create a variable out of results from count function to print and coomunicate
result = "P"
print(result)
print(str(arilY))
uart.write(str(arilY))
uart.write(result)
#these two functions print info to serial monitor and send
#to arduino the count & either Pass/Fail
def func_fail():
result = "F"
print(result)
print(str(arilY))
uart.write(result)
def func_orientation(arilX,seedX):
check = 0
check = (seedX - arilX)
if (check > 0) :
func_pass()
func_fail()
def func_ackee(Code,seedY,arilY):
if Code == 7: #if all three detectcted, focus on aril and draw rect
for seed in img.find_blobs([threshold_seed],pixels_threshold=200,area_threshold=200, merge=True):
img.draw_rectangle(seed[0:4])
img.draw_cross(seed.cx(),seed.cy())
img.draw_string(seed.x()+2,seed.y()+2,"seed")
seedY = seed.y()
for aril in img.find_blobs([threshold_aril],pixels_threshold=600,area_threshold=600, merge=True):
img.draw_rectangle(aril[0:4])
img.draw_cross(aril.cx(),aril.cy())
img.draw_string(aril.x()+2,aril.y()+2,"aril")
arilY = aril.y()
func_orientation(seedY,arilY);
func_position()
if Code == 3:
else :
#"bad ackee" designation, all three components not
# detectced. Automatic fail. Iterate countFail
seedY = seed.y()
#global arilY
arilY = aril.y()
func_position()
func_fail()
img = sensor.snapshot() # Take a picture and return the image. also where the terminal directs you when it crashes.
#initialize
Code = 0
ackee = False
seedY = 0
arilY = 0
for ackee in img.find_blobs(thresholds,pixels_threshold=200,area_threshold=200,merge=True):
Code = 7
func_ackee(Code,seedY, arilY)
