Sorry, i forgot to tell that im using bitmap file.
I made some tests and found that error is smaller when using QVGA (320x240px) frame size.
But like I already mentioned, there will be increasing frame difference number.
I modified the code to perform it using extra framebuffer and then result is better.
import sys, sensor, image, time, os, pyb, time, micropython
from pyb import Pin, SPI
sensor.set_pixformat(sensor.GRAYSCALE) # or sensor.GRAYSCALE
sensor.set_auto_whitebal(False) # Turn off white balance.
sensor.set_auto_exposure(False)
sensor.set_auto_gain(False)
sensor.skip_frames(time = 3000) # Let new settings take affect.
if not "frame" in os.listdir(): os.mkdir("frame") # Make a frame directory
#sensor.skip_frames(time = 3000) # Give the user time to get ready.
if not "reference.bmp" in os.listdir("/frame"):
img.laplacian(1, sharpen=True)
img.gaussian(2)
img.save("frame/reference.bmp")
sensor.snapshot().save
print("reference image saved")
# load reference image
refimage = image.Image("frame/reference.bmp")
extra_fb = sensor.alloc_extra_fb(sensor.width(), sensor.height(), sensor.GRAYSCALE)
extra_fb.replace(refimage)
i = 0
diff = 0
diffarray = bytearray(10)
while i < 10:
sensor.skip_frames(time = 100)
img.gaussian(2)
# Replace the image with the "abs(NEW-OLD)" frame difference.
img.difference(extra_fb)
hist = img.get_histogram()
# This code below works by comparing the 99th percentile value (e.g. the
# non-outlier max value against the 90th percentile value (e.g. a non-max
# value. The difference between the two values will grow as the difference
# image seems more pixels change.
diffarray[i] = hist.get_percentile(0.99).l_value() - hist.get_percentile(0.90).l_value()
i +=1
print(diffarray)
Result:
bytearray(b’\x01\x02\x02\x01\x02\x02\x01\x01\x02\x01’)
bytearray(b’\x01\x02\x02\x01\x02\x02\x01\x01\x02\x02’)
bytearray(b’\x01\x02\x02\x01\x01\x02\x01\x01\x02\x02’)
As you see, there is some differences, probably caused by sensor noise.
But when using this code, error will be increasing constantly: like +1 in 30 seconds
sensor.set_framesize(sensor.VGA) # or sensor.QQVGA (or others)
img.gaussian(2)
#refimage = image.Image("frame/reference.bmp")
#extra_fb = sensor.alloc_extra_fb(sensor.width(), sensor.height(), sensor.GRAYSCALE)
#extra_fb.replace(refimage)
i = 0
diff = 0
while i < 10:
img.gaussian(2)
img.difference("frame/reference.bmp") #extra_fb
i +=1
print(diffarray)
I have lot of OpenMV modules, at the moment i’ve tested two of them, and both will produce similar output so its not a single problem caused by faulty hardware.
