In OpenCV, for simpleBlobDetection there are two functions find_blobs & detect… Detect would return keypoints … Where as in openmv only find_blobs is there…
Any plan to add the detect function?
Any idea, how easily we can implement wrapper function for detect using openmv find_blobs?
I will explore more to understand the find_keypoints method. If you could give more pointers/explanation about where to look for or how the python code is mapping to imlib source, it would be helpful.
Does Find_keypoints() does it work the same way as OpenCV SimpleBlobDetectorImpl::detect function(Not the algorithm, just the functionality)? Keypoints returned would match?..
orb_find_keypoints has used below call.
// Gaussian smooth the image before extracting keypoints
imlib_sepconv3(&img_scaled, kernel_gauss_3, 1.0f/16.0f, 0.0f);
It looks like GaussianBlur… Is it correct?
