Ok, so just make a small movie and then return the amount of flowers.
There are 3 parameters in this line :
blobs = img.find_blobs([(90, 100)], merge=True, margin=-10)
Can you explain the 90 and 100 ?
Because how i read it it is area and pixels.
So when i want to detect only blobs that are bigger than 300 pixels i do this ?
blobs = img.find_blobs([(90, 300)], merge=True, margin=-10)
Only it doesn’t work.
90 and100 are the grayscale color thresholds applied to an RGb565 image. So, they are LAB thresholds on the L channel of the image which ranges from 0 to 100. Since the image is binarized only pixels of 0 and 100 in the LAB color space are in it.
You need to add a new parameter area= and pixels= to find_blobs().
Ok that’s make sense.
Only what do we here ?
img.binary([(0, 100, -2, 127, 6, 127)])
I’m was thinking these are the coler tresholds to detect the blobs ??
So now we are detecting blobs in greyscale, so is the global shutter cam better for this aplication ?
I’m binarizing the image first, then apply the erode and dilate filters, and then finding the blobs.
This is two threshold steps. The second step isn’t really needed… but, find_blobs() always thresholds things so I’m just passing it a list of thresholds that select an already thresholded image.
Ok, thank you for this short course openmv.
Just one simple question.
We checking plants on a conveyor belt so we trigger the cam with a plc trough modbus.
This works ok when we are connected with the pc software.
Only when we disconnected the pc software the cam reaction is different.
How is this possible ?
Is this a speed change ?
Can we give the cam a fix FPS ?
When connected to the PC the camera has the load of streaming images to the PC. When not connected it’s not loaded anymore.
You can give a fixed FPS by rate limiting the script using the pyb module:
import pyb
start_ms = pyb.millis()
if (pyb.mills() - start) < 50: pyb.delay(1)
start += 50
This above will limit you to 1000/50 = 20 Hz
I think there are some mistakes in this lines ?
import pyb
start += 50
This give errors.
When i do this:
import pyb
start = pyb.millis()
if (pyb.millis() - start) < 50: pyb.delay(1)
start += 50
There are no errors only there is nothing happened.
Yeah, I miss named the variable. But, do you see the idea of what the code is doing?
Yess i see where you want to go , only it doesn’t do anything.
import sensor, image, time
from pyb import UART
import pyb
from modbus import ModbusRTU
uart = UART(3,115200, parity=None, stop=2, timeout=1, timeout_char=4)
modbus = ModbusRTU(uart, register_num=9999, slave_id=0x03)
start += 50
if modbus.any():
modbus.handle()#debug=True)
if (modbus.REGISTER [0] == 1):
modbus.REGISTER[0] = 0
img.binary([(50, 100, -10, 127, 20, 127)])
img.dilate(7, threshold=19)
img.erode(2, threshold=19)
blobs = img.find_blobs([(90, 100)],pixels_threshold=180 , merge=False)
for b in blobs:
img.draw_rectangle(b.rect(), color=(255, 0, 0))
modbus.REGISTER[1] = (len(blobs))
print(len(blobs))
#print (modbus.REGISTER[0])
#print (modbus.REGISTER[1])
import pyb, time
while pyb.elapsed_millis(start_ms) < 50: pyb.delay(1)
start_ms += 50
if should have been while.
That’s looking more understanding.
Thank you alot.
