Hi there.
When I try saving multi images into SD card in a while loop like:
img = sensor.snapshot().compress(50)
img.save(path)
Problem is: the time usage of img.save(path) increases as the process goes on.
That for example,
when script starts running and saving the first dozens of images, img.save(path) needs 40-50 ms/image, but as more images been saved into SD Card, time usage of img.save(path) can slowly rise up from 50ms to 100+ms.
I can’t figure out why, Any help would be grateful.
Thanks.
It’s because you fill the directory up with images. The save() method has to find free space in the directory to save the image to which requires a scan of the directory in FAT. This costs time as it’s done 32-bytes at a time doing string compares.
If you want faster image saving using the ImageWriter format which makes one big file.
Also please make sure you’re using exFAT and Not FAT.
ok, I will test the gap of performances in both methods. As your proposed method ImageWriter() I can get one big file images.bin, there are some questions about it:
I want to read and process the saved images in PC, In other words, in PC, how can I convert .bin to Image Format like cv2::Mat or numpy.narray() or something that I can handle as images one by one?
Appreciate your kind reply.
Use the IDE video tools to convert the generated .bin file to a list of JPEG images. You can pass the output to be “%.jpg” and then the file will be split up into jpegs. One per frame. So, it may be a ton. Same for “%.png”
Thanks! for reply!
Following you instruction, I took several tests and would like share my result to those guys needed.
1 ImageWriter method to record uncompressed video
I test the imageio_write.py example, the API is named image.ImageIO(‘/path’, ‘w’) in this example, not image.ImageWriter(‘/path’, ‘w’) which can not work, I think image.ImageIO() method is what you mean too to get .bin file.
to deal with the .bin file in PC, we can use OpenMV IDE, or the the following python script:
#!/usr/bin/env python2.7
import cv2
import numpy as np
file = open("WVGA2.bin", "rb")
index = 1
img_byte = file.read(16 + 752*480) # in case the resolution is 752x480
img_np = np.fromstring(img_byte, dtype='uint8')
image = img_np[16:].reshape(480,752)
cv2.imshow('imshow',image)
cv2.waitKey(0)
print (index)
index = index + 1
file.close()
2 mjpeg.Mjpeg() method to record compressed video
seen in example mjpeg.py.
as a compressed format, the speed of recording is a little bit faster than uncompressed format, while if someone want to read .mjpeg in PC, you can try this one:
import cv2
import numpy as np
camera = cv2.VideoCapture('example.mjpeg')
index = 1
while(1):
print (index)
index = index + 1
retval, im = camera.read()
if not retval:
break
cv2.imshow("image", im)
k = cv2.waitKey(1)
camera.release()
Hi, Thanks for hints.
I actually used FAT before I issued this post, I checked the difference between exFAT and FAT, but I can not figure out why exFAT is suggested. So,
what is the reason to prefer exFAT?
is it a must in some cases?
Also, I did reformat the SD card to exFAT as you suggested, but little difference appears after that in my case. I don’t know whether I miss some thing. So would you please specify my doubt?
Great thanks.
Hi, I’m the next firmware release this will all run much faster. We have true double/triple buffering working now which allows the camera to capture frames while writing them to the disk.
How can I convert each frame of a .bin video file to individual JPEG images using the IDE? The Convert Video Output window has “File Name:” and “Save as type:”. There is no “Save as type” of “%.jpg”.
The conversion is powered by FFMPEG so you just need to pass output_%04d.jpg
