I noticed there is a canbus shield with a transceiver to power CANBUS applications. Does the new RT board require the same shield, or is it built onto the board already?
It requires a new shield. I have the designs for it done. But, we probably won’t be building it until next year. You can use the current shield we have if you are willing to add some wires to the bottom of the shield to fix pin locations.
Thanks for the reply. Is the pinout of the new board posted somewhere? We will likely just integrate the transceiver into our own receiver board. Just need some of the specifics.
I just have the shield docs: https://github.com/openmv/openmv-boards/blob/master/openmv5/can-rs232/can-rs232.pdf
This request has been asked for now multiple times. I will get this done on Sunday.
