i find a webpageOpenMV串口发送图片
in that page ,it has some code for send image by uart.write()
OpenMV串口发送图片
# Hello World Example
import sensor, image, time
from pyb import
uart = UART(3)
uart.init(115200, timeout_char=1000)
# Reset and initialize the sensor.
# Set pixel format to RGB565 (or GRAYSCALE)
# Set frame size to QVGA (320x240)
# Wait for settings take effect.
# Create a clock object to track the FPS.
# Update the FPS clock.
# Take a picture and return the image.
uart.write(img.compressed(quality=50))
# Note: OpenMV Cam runs about half as fast when connected
i have no idea if it will work ,i check the help:
UART. write (buf )
Write the buffer of bytes to the bus. If characters are 7 or 8 bits wide then each byte is one character. If characters are 9 bits wide then two bytes are used for each character (little endian), and buf must contain an even number of bytes.
Return value: number of bytes written. If a timeout occurs and no bytes were written returns None.
can usart send image by uart.write()?
