Calculating RAM Usage for TensorFlow Model on OpenMV Cam H7 Plus
Hello OpenMV Team,
I’m working with the OpenMV Cam H7 Plus to run a TensorFlow Lite model (MobilenetV2) for image classification and would like to understand how to calculate the exact RAM usage of the model in the frame buffer RAM.
I have attached my code and observed the following RAM usage:
import sensor, image, time, tf, uos, utime, gc
# Initialize the camera
sensor.set_windowing((224, 224)) # MobileNet typically takes 224x224 images
sensor.skip_frames(time=2000)
# Free memory before loading the model
free_memory_before = gc.mem_free()
# Record the start time for loading the model
start_load_time = utime.ticks_ms()
# Load the model from the SD card
model_path = 'Window_lightmodel_48.tflite'
net = tf.load(model_path, load_to_fb=True)
# Record the end time for loading the model
end_load_time = utime.ticks_ms()
# Calculate model load time (in milliseconds)
model_load_time_ms = utime.ticks_diff(end_load_time, start_load_time)
# Free memory after loading the model
free_memory_after = gc.mem_free()
# RAM usage (in bytes)
ram_usage = free_memory_before - free_memory_after
ram_usage_kb = ram_usage / 1024.0
print("RAM Usage (KB):", ram_usage_kb)
print("Model Load Time (ms):", model_load_time_ms) # Print model load time
def predict_image(img):
    # Run the image through the model
    predictions = net.classify(img)
    # Get the output tensor (assuming it's a list with a single value)
    prediction_output = predictions[0].output()[0]
    # Interpret the prediction
    predicted_class = 'Open' if prediction_output > 0.5 else 'Close'
    return predicted_class
# Lists to collect latency and throughput
latency_list = []
throughput_list = []
for i in range(21):
    # Capture an image
    # Start time
    start_time = utime.ticks_ms()
    # Predict the class
    predicted_class = predict_image(img)
    # End time
    end_time = utime.ticks_ms()
    # Calculate elapsed time
    inference_time = utime.ticks_diff(end_time, start_time)
    # Calculate latency in seconds
    inference_time_seconds = inference_time / 1000.0
    # Calculate throughput in inferences per second
    throughput = 1 / inference_time_seconds
    # Append to lists
    latency_list.append(inference_time)
    throughput_list.append(throughput)
    print('Predicted Class:', predicted_class)
    # Wait for 1 second
# Calculate and print average latency and throughput
average_latency = sum(latency_list) / len(latency_list)
average_throughput = sum(throughput_list) / len(throughput_list)
print('Average Latency (ms):', average_latency)
print('Average Throughput (inferences/s):', average_throughput)
Could you please provide guidance on how to accurately measure the RAM usage for my model in the frame buffer RAM? Is there a specific function or method that I can use to obtain this information?
Thank you for your assistance.
Hi, you need to recompile the firmware with FBALLOC stats defined in the command line argument passed to MAKE when building the firmware and then you need to load that onto your camera. If you do so then the camera will print out all large memory allocations as they happen.
The GC memory amount is the MicroPython heap which is not used for TensorFlow layers or the frame buffer.
Should I follow this documentation to do it?
There is no direct way on Windows?
firmware.zip (1.1 MB)
Hi, attached is the firmware for the H7 Plus with stats enabled. It will print each alloc followed by a peak number.
Thanks, it worked
