Automated Foosball Goalkeeper
HI, I am new to OpenMV. I would like to build an automated foosball goalie using an ESP32. There is no existing example on youtube. Any suggestion to me?
Foosball Table Setup: There are three defensive lane zones for the automated goalie rod: left, center, and right.
Color Representation: The orange ball represents the active game ball. (I don’t have to track the players, only the ball).
Single CAM Use: Only one CAM will be used, mounted directly above the pitch.
Goalie Rod Actuators: The goalie figures can slide left, center, or right to block the ball. (The mechanical electronic drive part will be completed by me using an ESP32 microcontroller, which must be used for this project.)
Ball Size: The diameter of the ball is 3.5 cm.
Game Settings Player Participation: The player will shoot the orange ball from the opposite side of the table toward the goal.
Shooting Distance: The shooting distance is about 1 to 1.5 meters, with a requirement for fast reaction speed, such as 0.1 seconds. The camera needs to process the image and provide electronic signal output to the ESP32 to move the goalie to the corresponding zone, or it may not require moving at all (e.g., three I/O ports).
Reaction Speed: Due to the very short distance and fast shots, there is a strict requirement for reaction speed, possibly requiring a response in 3 to 4 frames.
Trajectory Detection: It is necessary to detect the trajectory of the orange ball being shot, not just simple color detection.
Static Defense: Normally, the goalie figures sit in a closed/default stance.
Left Zone Reaction: When the player shoots the orange ball, the visual recognition system detects that the ball’s trajectory path is heading within the range of the left zone, causing the left I/O port to trigger to tell the ESP32 to slide the goalie to block it. It must not trigger other zones.
No Response for Other Zones: If the player shoots the ball and its path reaches the range of the center or right zone, the left zone I/O port must not respond.
Same Logic for Other Zones: The same logic applies to the center and right defensive zones when the ball is heading toward them.
I have seen several YouTube videos about doing this kind of thing using OpenCV on a laptop or Raspberry Pi, but I am entirely new to OpenMV hardware. How should I approach this trajectory tracking and ESP32 communication? Any code templates or tips would be a huge help!
Hi Suhail!
Thanks for the detailed post! We’ve been working hard on our documentation for the OpenMV Cam. Thanks to the increased quality, you can now ask Claude, for example, to write most of the application for you. Here’s a response from it for your project:
This is a response from Claude (Anthropic’s AI assistant), put together from the OpenMV docs.
This is a great first project, and the good news is that OpenMV is well-suited to it. The whole pipeline (color tracking → trajectory math → I/O output) runs on-device in MicroPython, so you don’t need a laptop or Pi in the loop. Here’s how I’d approach it.
The big architectural reality check first
Your hard constraint is reaction time: a ball traveling ~1–1.5 m, and you want a decision in ~0.1 s. That means your camera loop needs to comfortably hit a high frame rate, because “3–4 frames” of reaction budget only works if those 3–4 frames happen in well under 100 ms. The single biggest lever you have here is resolution and pixel format. Track the ball at QVGA (320×240) or even QQVGA in RGB565, disable auto-gain and auto-white-balance after warmup, and you can realistically get well over 100 fps for simple blob tracking. Don’t track at VGA — you don’t need the pixels, and they’ll cost you the reaction time you can’t afford.
Detecting the orange ball
For a single brightly colored ball, image.find_blobs() with a tuned LAB color threshold is the right tool — not the neural network stuff. It’s fast and deterministic. The single most important step for reliability is tuning your threshold under your actual table lighting using the Threshold Editor in OpenMV IDE (Tools menu). Don’t guess at the LAB values — point the camera at your table, grab a frame, and let the IDE generate them. And do lock auto_gain(False) / auto_whitebal(False), otherwise the camera will keep “correcting” the orange and your threshold will drift out from under you.
Trajectory detection (not just color)
You’re right that single-frame color detection isn’t enough — you need a heading. The standard approach: keep a short ring buffer of recent ball centroids, only treat the ball as “incoming” once it’s moving toward the goal, fit a straight line through the recent points, and extrapolate to your goal-line y to get the predicted crossing x. Then map that x to left/center/right by comparing against two boundary values you calibrate once. Linear extrapolation is fine here — over a flat 1.5 m foosball shot, curvature is negligible, so you don’t need any physics/gravity model.
Talking to the ESP32 — your “three I/O ports”
This maps perfectly onto machine.Pin. Configure three pins as outputs and drive the one matching the predicted zone HIGH (others LOW); the ESP32 just reads three GPIOs. Your spec (“the left port must trigger and must not trigger the others”) is just exclusivity — only one pin high at a time. A few notes:
  • The exact pin names depend on which OpenMV board you buy — check the Boards / pinout page for your model before wiring.
  • Watch your logic levels. Most OpenMV boards and the ESP32 are both 3.3 V, so you can usually wire directly — but confirm both sides are 3.3 V and share a common ground.
  • Add a confirmation count (require the predicted zone to agree across 2 frames) so a single noisy frame doesn’t twitch the goalie. With your frame budget you can afford a 2-frame confirm and still respond in time.
  • Alternatively, machine.UART lets you send richer data (predicted x, velocity) over two wires. Three GPIOs is the simplest thing that meets your requirement, so I’d start there and move to UART only if you want more than “which zone.”
Which board to get
Since reaction speed is the binding constraint, a faster board gives headroom; you’ll want the AE3, N6, or H7 R1 as these cameras can run at 120+ FPS out of the box.
Complete starter script
Here’s a full, runnable script that does all of the above — blob detection, the least-squares trajectory fit, zone mapping, the confirmation filter, and the three output pins. I’ve tested the trajectory math separately; you’ll need to plug in your own LAB threshold from the IDE and calibrate the four geometry constants at the top (goal-line y and the two zone boundaries) to your camera mounting:
# Automated Foosball Goalkeeper - OpenMV
# Tracks an orange ball, predicts which goal zone (left/center/right) it is
# heading toward, and drives one of three GPIO output pins HIGH to signal an
# ESP32. Designed for high frame rate so the decision lands within a few frames.
# WORKFLOW BEFORE RUNNING:
#   1. Use Tools -> Machine Vision -> Threshold Editor in OpenMV IDE to get the
#      LAB threshold for YOUR orange ball under YOUR table lighting. Replace
#      ORANGE_THRESHOLD below with the values it gives you.
#   2. Confirm the pin names ("P0"/"P1"/"P2") exist on your specific board
#      (check the Boards / pinout page for your model).
#   3. Confirm both OpenMV and ESP32 are 3.3V I/O and share a common ground.
#   4. Calibrate GOAL_LINE_Y and the two zone boundaries (see CALIBRATION).
# CONFIGURATION
# LAB threshold: (L_min, L_max, A_min, A_max, B_min, B_max)
# Orange sits in positive A and strongly positive B. TUNE THIS in the IDE.
ORANGE_THRESHOLD = [(20, 90, 10, 60, 25, 90)]
# CALIBRATION (all in image pixel coordinates at QVGA = 320x240) -------------
# Camera is mounted directly above the pitch. Assume the goal is along the
# bottom edge of the frame and the ball travels toward increasing y.
GOAL_LINE_Y      = 230   # y of the goal line (where the goalie rod sits)
ZONE_BOUNDARY_L  = 107   # x < this  -> LEFT zone
ZONE_BOUNDARY_R  = 213   # x > this  -> RIGHT zone; between the two -> CENTER
# TUNING ---------------------------------------------------------------------
HISTORY_LEN      = 5     # how many recent centroids to keep for the line fit
MIN_POINTS_FIT   = 3     # need at least this many points before predicting
MIN_FORWARD_DY   = 1.0   # px/frame toward goal before we treat it as a shot
CONFIRM_FRAMES   = 2     # predicted zone must agree this many frames in a row
PIXELS_THRESHOLD = 20    # ignore blobs smaller than this (noise)
ZONE_LEFT, ZONE_CENTER, ZONE_RIGHT = 0, 1, 2
# HARDWARE: three output pins to the ESP32
left_pin   = Pin("P0", Pin.OUT_PP)
center_pin = Pin("P1", Pin.OUT_PP)
right_pin  = Pin("P2", Pin.OUT_PP)
def signal_zone(zone):
    """Drive exactly one pin HIGH (or all LOW if zone is None).
    Exclusivity is enforced here: triggering one zone guarantees the other
    two stay LOW, which is exactly the behavior the project requires.
    left_pin.value(zone == ZONE_LEFT)
    center_pin.value(zone == ZONE_CENTER)
    right_pin.value(zone == ZONE_RIGHT)
def zone_for_x(x):
    """Map a predicted goal-line x-coordinate to a defensive zone."""
    if x < ZONE_BOUNDARY_L:
        return ZONE_LEFT
    elif x > ZONE_BOUNDARY_R:
        return ZONE_RIGHT
    return ZONE_CENTER
def predict_crossing_x(history):
    """Least-squares fit x as a function of y over recent points, then
    extrapolate to GOAL_LINE_Y. Over ~1.5 m of flat travel a straight line
    is plenty -- no physics/gravity model needed.
    history is a list of (cx, cy) tuples. Returns predicted x, or None if the
    points are degenerate (e.g. ball not really moving in y).
    n = len(history)
    sum_y = sum_x = sum_yy = sum_xy = 0.0
    for (x, y) in history:
        sum_x += x
        sum_y += y
        sum_yy += y * y
        sum_xy += x * y
    denom = (n * sum_yy) - (sum_y * sum_y)
    if abs(denom) < 1e-6:
        return None  # all points at ~same y; can't extrapolate a heading
    # x = slope * y + intercept
    slope = ((n * sum_xy) - (sum_x * sum_y)) / denom
    intercept = (sum_x - (slope * sum_y)) / n
    return (slope * GOAL_LINE_Y) + intercept
# CAMERA SETUP
csi0.framesize(csi.QVGA)         # 320x240 -- small = fast. Don't use VGA here.
csi0.snapshot(time=2000)         # let AWB/AGC stabilize on startup
csi0.auto_gain(False)            # CRITICAL: lock exposure...
csi0.auto_whitebal(False)        # ...and white balance so the threshold holds
# MAIN LOOP
history = []                     # recent (cx, cy) centroids
candidate_zone = None            # zone we are about to confirm
candidate_count = 0              # how many frames it has agreed
signal_zone(None)                # start in the default (idle) stance
    blobs = img.find_blobs(ORANGE_THRESHOLD,
                           pixels_threshold=PIXELS_THRESHOLD,
                           area_threshold=PIXELS_THRESHOLD,
                           merge=True)
    if blobs:
        # The ball is the largest matching blob.
        ball = max(blobs, key=lambda b: b.pixels())
        cx, cy = ball.cx(), ball.cy()
        img.draw_rectangle(ball.rect(), color=(255, 0, 0))
        img.draw_cross(cx, cy, color=(0, 255, 0))
        history.append((cx, cy))
        if len(history) > HISTORY_LEN:
            history.pop(0)
        # Is the ball actually heading toward the goal?
        moving_forward = False
        if len(history) >= 2:
            dy = history[-1][1] - history[-2][1]
            moving_forward = dy >= MIN_FORWARD_DY
        predicted_zone = None
        if len(history) >= MIN_POINTS_FIT and moving_forward:
            px = predict_crossing_x(history)
            if px is not None:
                predicted_zone = zone_for_x(px)
                img.draw_line(history[-1][0], history[-1][1],
                              int(px), GOAL_LINE_Y, color=(0, 0, 255))
        # Confirmation filter: require the same zone for CONFIRM_FRAMES frames
        # so a single noisy frame can't twitch the goalie.
        if predicted_zone is not None and predicted_zone == candidate_zone:
            candidate_count += 1
            candidate_zone = predicted_zone
            candidate_count = 1 if predicted_zone is not None else 0
        if candidate_zone is not None and candidate_count >= CONFIRM_FRAMES:
            signal_zone(candidate_zone)
        # Ball not visible -- clear history so a new shot starts fresh.
        history.clear()
        candidate_count = 0
        signal_zone(None)         # return to idle/default stance
Suggested build order
  1. Get find_blobs reliably locating the ball and printing fps. Confirm you’re well above 100 fps at QVGA.
  2. Add the centroid history and print the predicted goal-line crossing x. Verify it tracks reality by rolling the ball slowly.
  3. Calibrate GOAL_LINE_Y and the two zone boundaries.
  4. Wire up the three pins and test the full loop.
  5. Tune CONFIRM_FRAMES and MIN_FORWARD_DY for jitter vs. latency.
A couple of the “related topics” the forum surfaced under your post — the ball trajectory detection with 100ms reaction time thread and the golf ball detection, speed and direction thread — are tackling almost exactly your problem and worth reading; they’ll have real tuning numbers from people who hit the same frame-rate wall.
Happy to go deeper on any single piece if you tell me which board you end up getting.
https://www.youtube.com/watch?v=hE_iPnvVJ4Q
This is the project I’m trying to build, I purchased the AE3 camera hoping it can track, calculate the speed and predict trajectory of the ball and send signals to a microcontroller (not decided yet which one to use) and move the goalie rod using a servo motor and block the ball at the exact predicted coordinates, not left, right and center as i said earlier. Am I able to do that with AE3? Thank you.
Yes, that’s very doable on the AE3.
