Hi.
I am benchmarking the H7 and H7plus boards equipped with the OV7725 sensor because I have an application that requires the highest possible fps.
The IDE updated the firmware of both boards to 3.6.4
I need an image VGA and Grayscale for one part of the program and also need to detect Apriltags from the same image.
To detect the Apriltags, I made a copy of the VGA image to QQQVGA
The program is as above:
import sensor, image, time
sensor.set_framesize(sensor.VGA
sensor.set_auto_gain(False)
img = sensor.snapshot().copy((0, 0, 640, 480), 0.125 ,0.125)
img.find_apriltags()
I was expecting a higher fps with the H7plus board but, instead, with the H7 board I got 30 fps and with the H7plus board I got 15 fps.
What am I doing wrong?
Is there any way of going beyond?
Thank you for your help.
