April Tags with MT9V034
Okay, you can use the motor shield with the stepper motor example.
Hi, is it possible to track pattern in 360 degrees using openMv H7P?
Yes
Apriltag is not support to detect 360 degrees right? is there any way to detect the pattern in 360 degrees?
It’s supported for 360 degrees.
I placed Apriltag on one pole and rotate camera module in 360 degrees. in that case it will detect only 90 degrees, after 90 degrees camera module will not capture full pattern of AprilTag because camera will take half of the pattern so camera module will not detect. How i test 360 degrees? is there any demo video. if it is please send me on sllubateb@gmail.com or here.
You need to make sure the tag is completely visible in the camera. We do not handle occluded tags.
