AE3 LEGO®-compatible case
I’m using an AE3 camera in conjunction with LEGO® Spike™ Prime robotic system. I have designed and procured an appropriate adapter cable so that the camera can be connected directly to the LEGO® LPF2-style hub ports and made a clip-in case to easily integrate the camera in robots made out of LEGO Technic bricks/beams.
The case is fully 3D-printable, interested readers can find the print files in two different variants here:
https://www.printables.com/model/1873547
Case variant 1 (mounting holes on the back of the case, the case is somewhat thick):
Case variant 2 (mounting holes on the sides of the case, the case is quite wide)
Both case variants come with a lens cap / camera protector cover:
Update:
Both version pay close attention to mounting holes alignment. The lens is placed exactly between mounting holes:
The IMU axis is exactly in the midplane of the mounting ‘ears’ for the side-mounted case - the tan pins are the pivot axis going through the centre of the IMU:
For the back-mounted case the centre of the IMU is one stud above the mounting holes, again the tan pins are the pivot axis through the IMU:
Enjoy.
Want me to make a section on the product page and link to your design?
If you’d like - why not :slight_smile:
Posted!
Cool!
