The main page for the H7 claims 75FPS at VGA resolution is possible, but I seem to max out at exactly 60 (Grayscale, forced off auto exposure, gain, wb to low values). I can get 150, as advertised, for QVGA Here’s the code I’m uploading
import sensor, image, time
sensor.set_framesize(sensor.VGA) # Set frame size to QVGA (320x240)
sensor.set_auto_exposure(False,100)
sensor.set_auto_gain(False,0,0)
I’ve tried variations (Bayer, rgb). Nothing seems to raise it above 60.
