Pictures attached. See anything odd?
Thank you!
Kevin
IMG_0822.MOV (6.19 MB)
If u can’t see the video, I’s just me plugging it in then the green light flashes then the white / blue flasing.
Any diagnostic firmware that can help isolate this?
Interesting… um, can you try this. Please remove the camera module. The board should work without one. This will verify the firmware is okay. Also, is this is new camera that has not yet had firmware loaded? I think I might know the error if you have never updated the firmware.
With FLIR and Adapter - White/Blue flashing light
Without ( FLIR and Adapter ), just the little with connector on the PCB - White/Blue flashing light
With your original camera - works just fine!
Firmware update?
Thank you!
Kevin
No, this implies the flir lepton or the adapter is bad. Can you confirm the flir lepton is okay using another system?
