Might want to double check the model is not corrupted, if you reset the camera after copying a file without safe removing the disk (eject/unmount) files get corrupted.
The gray-line error says: Input model data type should be 8-bit quantized!
However I have performed the quantization by following Quantização pós-treinamento | TensorFlow Lite It quantizes the model to 8 bits.
Thanks.
Can you verify that your input is an 8 bit unit or int and output is an 8 bit unit or int? This is probably not the case if you are getting that error.
