Just unboxed the camera and would like to see a green lane, however, the camera is only seeing in B&W. Screenshot attached.
Hi, you need to turn white balance off immediately. White balance makes the world look gray depending on what it sees. If green if the only color in view it will change the color of green to gray to “white balance”. Please wait do skip_frames(time=200) and then turn auto gain and white balance off.
Works like a charm! Thank you so much!You’ve done an amazing job with the product, but even more so, with the support!!
