Hello all I’m extremely new to using the OpenMV IDE and ecosystem, I feel I’ve done pretty well so far with using example scripts and AI-generated bits of code but i have a bit of a technical question that im unable to find an answer to, whether that be from lack of familiarity of not enough experience im not sure and apologies if this is a simple fix.
My Question:
i have used Edge Impulse to create a trained object recognition model to identify a tennis ball, this works well for my first try, i have put the trained.tflite and labels.txt files onto my H7 camera. i run my script that uses the trained model to find tennis balls in the frame. this works great but my concerns lay with the accuracy of this. When a tennis ball is detected it draws a cross on the centre but when i move the camera the cross seems to step in large across the screen and often is off-centre from the ball as its sitting in between one of these steps. Is there something i can adjust or implement to help the centre of the object recognition not jump by values of 10 and allow it to move 1 value at a time for accuracy?
Below is an example if how the X and Y values move in increments of 5-10, this is a serial print of the values from the net.detect image function.
X:55,Y:70,Size:30
X:65,Y:75,Size:30
X:65,Y:70,Size:30
X:65,Y:65,Size:28
X:75,Y:65,Size:30
X:75,Y:65,Size:30
X:75,Y:65,Size:32
X:80,Y:65,Size:32
X:85,Y:70,Size:32
Here is the code from my script:
import sensor, image, time, os, tf, math, uos, gc
from pyb import UART
# Initialize the camera sensor
sensor.set_windowing((180, 140))
sensor.skip_frames(time=2000)
sensor.set_auto_exposure(True)
sensor.set_auto_gain(True)
# Initialize UART communication
uart = UART(3, 9600)
# Load the TensorFlow Lite model
# Make sure to handle exceptions if the model fails to load
net = tf.load("trained.tflite")
except Exception as e:
print('Failed to load TensorFlow Lite model:', e)
sys.exit()
# Read labels from the labels file
print('Failed to load labels:', e)
sys.exit()
# Define color palette for detection annotations
colors = [
(255, 0, 0), # Red
(0, 255, 0), # Green
(0, 0, 255), # Blue
# Main loop
img = sensor.snapshot(sensor.JPEG).lens_corr(strength=1.5, zoom=1.0, in_place=True)
found_circle_in_frame = False
# Perform object detection
for i, detection_list in enumerate(net.detect(img, thresholds=[(160, 255)])):
if i == 0 or not detection_list:
for d in detection_list:
[x, y, w, h] = d.rect()
center_x = x + (w // 2)
center_y = y + (h // 2)
img.draw_cross(center_x, center_y, color=colors[2])
# Assuming global circle detection is intended
found_circles = img.find_circles(
threshold=4000,
x_margin=10,
y_margin=10,
r_margin=10,
r_min=2,
r_max=300,
r_step=2)
if found_circles: # Check if at least one circle is found
ball_r = found_circles[0].r() # Use the first found circle
print("Ball Drawn\n")
img.draw_circle(center_x, center_y, ball_r, color=(255, 0, 0))
found_circle_in_frame = True
# Simple area estimate based on the circle's radius
size_estimate = ball_r * 2
uart.write(f"X:{center_x},Y:{center_y},Size:{size_estimate}\n")
print(f"X:{center_x},Y:{center_y},Size:{size_estimate}\n")
if not found_circle_in_frame:
# Handle frames where no circles are found
print("No circle detected in this frame.")
#_END CODE_ :)
Any help is appreciated
