Counting faces!
Counting faces!
Postby iabdalkader » Thu Jul 09, 2015 8:05 pm
Hey, I've been asked before about the face detector, if it can detect more than just one face, the answer is yes, here's a test:
The detector can also be tuned for speed or accuracy, depending on the parameters you pass to the detector. It can also detect other objects too, depending on the cascade you're using, recently I added two common cascades to the flash (face and eye) so those are built-in they don't use any RAM, and you can still load different (or custom) cascades from the uSD.
